Go to Post If it's not on fire, it's a software problem. - Matt Leese [more]
Unread 07-10-2007, 00:20
bilal1219's Avatar
bilal1219 bilal1219 is offline
AKA: Bilal
FRC #1219 (Iron Eagles)
bilal1219 is an unknown quantity at this point
CD RW Problem
Hey guyz,
I got a problem with my cd RW drive. I currently have CD reader, CDRW and DVD Combo in one cd drive. But the problem im facing is that it works as a cd reader i.e i can easily install and run anything on cd and DVD. but when it comes down to burn a cd. It just goes to 8 % and then says "the burn process failed". This happens for ever file that i try to burn on a cd. I have tried All new cd's but says the same thing. And One very suprising thing is that the cd doesent get destroyed. i.e I can reuse it again.
PS: Im using NERO 7 Ultra Edition for burning CD's.
I will be very grateful if someone can help me out with this problem.
Bilal Shahid.
<a href="http://www.thebluealliance.net/tbatv/team.php?team=1219" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/1219/FF3300/0066FF/teambadge.png" alt="Team 1219" /></a>
Robots Might Lose But Teams Never Do
Unread 07-10-2007, 09:47
Chief Pride's Avatar
Chief Pride Chief Pride is offline
&lt;3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Re: CD RW Problem
a CD-RW is not the same as a CD-R
CD-R = Recordable
CD-Rw = ReWritable
even if the burn had finished you would have been able to erase what is on the disk and write on it again
now, about your burning problem, do two things, reinstall nero, and make sure your buffer underrun is turned on :>
Unread 07-10-2007, 10:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: CD RW Problem
My Computer, Select the drive, right click, properties, recording, Enable CD Recording on this drive checkbox.
That's the only idea I have. I have come across that unchecked before.
Unread 07-10-2007, 10:52
&lt;3
AKA: James Kiefer
Re: CD RW Problem
yes, but if it was that problem it wouldve never made it to 8% :S
alhough, i have hadd that box come unchecked on me too
Unread 07-10-2007, 19:22
bilal1219's Avatar
AKA: Bilal
Re: CD RW Problem
Hey guyz,
I have checked all the possiblities as mentioned above.But the thing which comes into my mind is that cd R should not run (I.E no burniong at all) if the burner dosent wrk.but the thing is it goes for sometime like 8 - 10 % and then says it failed. Can verify this problem.I even tried looking on the websites.
Bilal Shahid
Team 1219
Unread 07-10-2007, 19:36
&lt;3
AKA: James Kiefer
Re: CD RW Problem
your sure its not the media?
clear your caches, temp files, and check if any new software has been installed
if that doesnt work go get one of those head cleaning cd's and pop that in, also, clean up your HDD a bit
ADC problem sjung9442 Programming 4 17-02-2006 11:12
G.T.S ..... (problem) Ami Schwartz Programming 3 28-01-2006 17:01
Problem Hailfire CD Forum Support 7 06-10-2002 15:02
PROBLEM!!!!!!?????? Clark Gilbert CD Forum Support 9 02-12-2001 12:43
