Go to Post I see you've one-upped me in the stripped gear game. I commend you. - frcguy [more]
View Poll Results: Which of the following does your team use?
MPLab 45 72.58%
EasyC 15 24.19%
WPILib 6 9.68%
Other 11 17.74%
Multiple Choice Poll. Voters: 62. You may not vote on this poll
Unread 07-10-2007, 13:25
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
What programming tool does your team use?
Just curious...
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
Unread 07-10-2007, 14:22
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Re: What programming tool does your team use?
I checked WPILib and Other because our robot was programmed using WPILib in Eclipse instead of in MPLab last year. Everything works the same code and compile wise, just with a different IDE.
Unread 07-10-2007, 14:27
ham90mack's Avatar
So does that mean Kevin Watson's code is kind of like WPILib? They both are used in MPLab, but both are different default code bases? Or am I wrong? (my team only uses Kevin Watson's code with MPLab)
Old stuff:
Unread 07-10-2007, 14:50
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
WPIlib is a framework written by Brad Miller at WPI to greatly simplify robot programming. Here's some more info:
http://users.wpi.edu/~bamiller/WPILib/
Team 228 wrote our robot code last year in WPIlib, so we can work with it in MPLAB and EasyC PRO. And since WPIlib takes care of so much 'back-end stuff' for you, our team was able to concentrate on more important programming tasks, like our drive-by autonomous mode.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-10-2007, 15:10
ham90mack's Avatar
In that case, I might want to consider the ability for my emulator to work with WPILib after making it work with Kevin Watson's MPLab code if it is popular enough...
Old stuff:
Unread 07-10-2007, 15:15
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
This was my first year as a programmer and we used the EasyC program. It was really easy to learn and a great teaching tool for anyone who wants to learn programming.
Unread 07-10-2007, 16:20
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
code::blocks
Unread 07-10-2007, 20:01
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Does anyone know if the source to WPILib is available? We use MPLab now because we can't figure out how to teach device driver development using WPILib or EasyC. To us the beauty of KW's software is you can pretty much just use it if you need a quick solution but because you have the source you can also learn how the microcontroller works and develop your own device driver and interrupt code. The FRC robotics program is usually the first opportunity our software developers have to really understand something about embedded development and understanding something about how to read a data sheet and configure the mc registers. This gives them the confidence to develop additional functionality on the FRC controller as well as use other co-processors such as the nice Atmel microcontrollers.
Unread 08-10-2007, 11:23
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
WPIlib source isn't available.
Unread 11-10-2007, 20:13
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Originally Posted by bear24rw View Post
code::blocks
Are you serious? How? I used that as my primary programming tool before I got Visual C++
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 11-10-2007, 22:52
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
http://www.chiefdelphi.com/forums/sh...37;3A%3Ablocks
lol there you go..
Unread 11-10-2007, 23:02
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
We've used MPLab in the past, but I'm thinking we'll give WPILib a good look this year. It seems like an incredibly simple and powerful tool.
Unread 11-10-2007, 23:04
Nathan's Avatar
Cool, thanks. I'll have to check that out...
Unread 12-10-2007, 02:00
I checked Other because we run the compiler on Linux (using wine) and use Makefiles and vim (a text editor) instead of MPLAB.
Unread 12-10-2007, 21:17
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Eclipse all the way!
To be honest, I'm surprised at the number of people who are still using the MPLAB IDE, given the number of "real-world" options like Eclipse. I guess it's primarily because MPLAB can be installed by default from the CD.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
CT Teams - What does your school system provide your team WDAtiyeh General Forum 5 05-03-2007 19:23
Who does the programming for your team? EHaskins Programming 39 26-11-2006 16:49
What does your team use to make the clovers for tetras? Tigerlily-87 General Forum 54 13-02-2005 20:03
What technologies does your team's website use buss Website Design/Showcase 14 30-05-2004 19:30
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
