Go to Post Where's my hammer? I need a bigger hammer. - JaneYoung [more]
Unread 07-10-2007, 23:12
CraigHickman
Posts: n/a
Colson Wheel
Hey all-
I'm doing a CAD for a battlebot project (it'll fight in combots, vertical blade spinner), and am going to use Colson wheels for it.
Does anyone happen to have either Inventor or Solidworks Models of them?
Unread 07-10-2007, 23:16
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Colson Wheel
Originally Posted by 114ManualLabor View Post
Hey all-
What size colson you need?
I know we have the 6'x2' NPC colsons at school saved in inventor 11 format.
-Chuck
Unread 07-10-2007, 23:27
CraigHickman
Posts: n/a
Re: Colson Wheel
I was hoping for the 3 or 4 inch ones...
(I'm not even sure they make a 3 inch, but that'd be the one I want)
Unread 08-10-2007, 00:27
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
Re: Colson Wheel
sweet your doing combots. i am aw well not sure what i am going to build this year. try rfl there should be links on there. http://forums.delphiforums.com/THERFL/start
If it isn't broken, Fix it till it is ~ Baker
Unread 08-10-2007, 00:30
REVving up for a new season
FRC #2848 (All-sparks)
Re: Colson Wheel
I know it is nice to have exact cad models of the wheels but for all intensive purposes you can just grab dimensions from http://www.robotmarketplace.com/mark...e_colsons.html
and draw cylinders which fit the model you are looking at.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 08-10-2007, 02:43
AdamHeard's Avatar
Lead Mentor
Re: Colson Wheel
That's what I did for the 1.625, 3 and 4 inch ones seen on banebots/robotmarketplace. I can appreciate thoroughness in CAD, but really all that matters is the OD and the width in terms of the design. An exact model isn't going to really help at all. Now, to completely contradict myself.... I did do some work on the models to make them match the shape (slight taper on the tread, groove between hub and outer surface, etc..) pretty close for cosmetic reasons.
But, c'mon. You're Craig Hickman.... You'll end up with a perfect model one way or another.
Unread 10-10-2007, 19:14
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Re: Colson Wheel
I've got models for 2x7/8, 3x7/8 and 3x1.5. I've also got a rough drawing of a 3x7/8" colson with a cncbotparts hub in it that I'd made before finding the others. If you want any of them, let me know.
Team 675-Alumni
Near Chaos Robotics
Unread 10-10-2007, 19:26
CraigHickman
Posts: n/a
Re: Colson Wheel
I actually finished my own model about 12 minutes after I started. And like Adamheard said, it's perfect (to my standards anyway)
After all, it is mostly aesthetic.
Unread 10-10-2007, 19:41
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Colson Wheel
Really only matters when you plan to FEM, not sure if you have to do that or not but it could be important. I've not really worked too much with FEM in Inventor, but of course the shape matters then for stress concentrations and what not. Otherwise like you said cylinders could work out just fine.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Mounting Colson Wheels gnirts Technical Discussion 3 14-01-2007 17:41
pic: Colson Wheel and Sporcket. Gabe Extra Discussion 4 15-11-2006 13:56
Colson Wheels sanddrag Technical Discussion 11 22-03-2006 10:02
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
