Go to Post Thanks for the heads up on the elevator game. - Andrew_L [more]
Go Back   Chief Delphi > Old Forum Archives > 1999
Unread 23-06-2002, 21:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
How stuffed are the floppies?
Posted by Ian, Student on team #188 from Woburn C.I..
Posted on 3/3/99 2:46 PM MST
Well, the message pretty much says it all...I'm wondering how much the floppies are generally stuffed (I'm the human player for my team and it affects how I practice). Also, does FIRST generally replace floppies that have become crushed or do we just have to deal with it?
#0047 (ChiefDelphi)
REALLY STUFFED!
Posted by David, Student on team #269, BruQuest, from Oconomowoc High School and Quest .
Posted on 3/3/99 5:42 PM MST
In Reply to: How stuffed are the floppies? posted by Ian on 3/3/99 2:46 PM MST:
Hi
To our suprise the floppies at the competition were REALLY STUFFED. That
was a problem for us because we designed our basket for the floppies we
had gotten from first (which didn't seem to be very stuffed). So at the
competition we had a problem in fitting floppies into our basket.
I think they replace damaged floppies, although there was only one damaged
floppy in the whole competition as far as I remember.
CYA + good luck
David
#0047 (ChiefDelphi)
Re: REALLY STUFFED!
Posted by Bethany Dunning, Coach on team #163, Quantum Mechanics, from International Academy and Quantum Consultants/EATON/ITT Industries.
Posted on 3/4/99 6:16 AM MST
In Reply to: REALLY STUFFED! posted by David on 3/3/99 5:42 PM MST:
They replace "damaged" floppies, but originally in the competition manual,
it was stated that the floppies unless damaged (and i assumed that to mean
pretty much falling apart) they would be used all day. Now, the floppy that
we got at kick-off is pretty much flat now, from being tossed around, and
played with, and having the peanuts, and I assumed that at the end of a competition
day, the field floppies would be in a similar state. Comments?
: Hi
: To our suprise the floppies at the competition were REALLY STUFFED. That
: was a problem for us because we designed our basket for the floppies we
: had gotten from first (which didn't seem to be very stuffed). So at the
: competition we had a problem in fitting floppies into our basket.
: I think they replace damaged floppies, although there was only one damaged
: floppy in the whole competition as far as I remember.
: CYA + good luck
: David
#0047 (ChiefDelphi)
Re: Not every day
Posted by Raul, Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 3/4/99 11:35 AM MST
In Reply to: Re: REALLY STUFFED! posted by Bethany Dunning on 3/4/99 6:16 AM MST:
They were very stuffed the practice day and gradually deflated over the 3 days. This was also evident since were able to fit 7 or 8 in our basket the last day and could only fit 5 or 6 on the practice day. We got one tangled in our drive system in the quarter finals. When I took it out, I noticed that it was quite noticeably flat. I did not notice if they replaced it for the next matches. So be prepared for all conditions.
Raul
[IMG] code is Off
You know you are a FIRST-a-holic when...... archiver 2000 12 23-06-2002 23:06
Dare I say Footballs? archiver 1999 23 23-06-2002 22:51
New Poll! (17) archiver 2000 1 23-06-2002 22:36
Packed floppies and big balls archiver 1999 0 23-06-2002 21:59
FIRST themed rooms David Kelly General Forum 50 06-07-2001 11:11
