Go to Post Mentors build mentors. - Siri [more]
Unread 09-10-2007, 00:16
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: pic: Our new cart, pic 1
So you plan on powering it up every time you want to move the cart? Even if you have to move it 2 feet?
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 09-10-2007, 11:40
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
The beauty of embedded processing... it takes less than a second to boot up a FRC controller... i'm assuming thats what you're using...
Plus, I doubt the cart uses much energy on 'stand by' (not moving) so you could probably leave it on all the time, just put a quick disconnect on it so you can just hook it to your charger whenever its in your pit.
If you're handy with a lathe and/or a vertical mill, you could make a nifty magnetic power connector (like on a mac, but bigger) pretty easily out of some brass and HDPE (or delrin or any insulative, rigid plastic of your choice). Always wanted to make one of these... but never had an application for it yet.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 09-10-2007, 13:20
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
can u explain that a little more? i am very interested
Unread 09-10-2007, 13:37
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
-q
The cart is actually capable of being hooked up to shore power and when it's, let's say, in the pit....the inverter is turned off and shore power is connected.
Unread 09-10-2007, 20:18
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Guys, have faith in our engineering skills. The cart is a completely self sufficient electrical and mechanical system that can stay active for a full day with the drive system being used and 2 days of just charging batteries (without needing a recharge). Every system has a redundant system to back it up in case of a failure. The system is charged by one AC input to a custom designed distribution box using relays to select shore power or inverter power. It has a descent speed and a relatively tight turning radius. It is very safe for the user as well as the surrounding people. For the driver it has a 4 point restraint system and for other people the cart has an emergency braking system that brings it to a stop within inches.
As for the magnetic shore power plug, that would be very unsafe, because when the magnet disconnects you now have a situation where the leads can be easily shorted, or shock someone.
Championship - Delphi "Driving Tomorrows Technology"
pic: Our New Team. Michelle Celio Extra Discussion 2 07-09-2007 10:11
pic: 1029 cart - Rene de Cart bjimster1 Extra Discussion 6 03-03-2007 20:47
pic: Finally, our new milling machine Mark McLeod Extra Discussion 11 23-09-2006 18:30
pic: Our New T-Shirt Design!!! Nathan Pell Extra Discussion 19 10-01-2005 00:10
pic: Our new robot CD47-Bot Robot Showcase 3 20-01-2004 00:01
