Go to Post Like his father, John V-Neun will soon have the advantage of his head resembling a game object. - Eric O [more]
Unread 09-10-2007, 16:43
Re: OI control box, LED questions
Originally Posted by Tanis View Post
As for the light mappings in the code, I'm not talking about where it ells the light whether to turn on or off, I'm talking about where it says that pinX = relay1_green. I found where it sets the p1_x, y, switch, trig, and the other inputs, but I couldn't find the outputs.
Those pins are a hardware feature of the OI. There's no code associated with them, other than the code which turns the LEDs on or off. You can find the pinout in the OI reference guide that you can download here; look for the documentation of ports 1 and 3.
Is there a guide out there for using the dashboard port for inputs/outputs?
It's output only. The dashboard specification is included in the .zip file with the Dashboard Viewer program.
pic: a control box CD47-Bot Extra Discussion 30 16-03-2004 00:08
Control Box Bling phrontist General Forum 4 08-02-2004 21:07
Custom Control Box D.Viddy Programming 3 15-02-2003 11:35
Box Control Tton General Forum 2 12-02-2003 23:38
control box archiver 2000 8 24-06-2002 00:20
