Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Unread 18-08-2007, 22:58
CraigHickman
Posts: n/a
pic: 4 motor Gearbox CAD
Unread 18-08-2007, 22:59
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Re: pic: 4 motor Gearbox CAD
How would you work that in to a crab drive?
Is that for one pod?
or,
a central unit that turns all four?
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 18-08-2007, 23:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
or,
More than likely a single unit that powers all the modules in a co-axial swerve system. Other modules would be used for steering the wheels.
Unread 19-08-2007, 00:40
CraigHickman
Posts: n/a
Exactly.
Unread 19-08-2007, 09:22
GBIT's Avatar
AKA: Jared
ok that is what i figured but i didn't want to assume it.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 19-08-2007, 10:03
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Wouldn't it be easier and better to have 2 gears, with 2 CIMs in each. Each Gearbox controls a pair of wheels?
If im wrong, what do you think are the advantages of a 4 CIMs-in-one-gear?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 19-08-2007, 10:55
REVving up for a new season
FRC #2848 (All-sparks)
The advantage is all in the power distrubution. If you have all four cims in one gearbox, each wheel is taking an equal amount of power when the weight is centralized. If one wheel looses traction (due to a shift in the center of mass) the full power of the drive will still be used (assuming no wheel slipping).
If you had 2 gear boxes on each side if one side of the robot looses traction you effectively loose half your power. Now considering the real world, the odds of your robot loosing complete traction on one side and still being able to drive would be an accomplishment in itself.
Ultimately having a centralized drive does give some advantages for serviceability, and maybe even weight, but I would still prefer 2 serrate gearboxes
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-08-2007, 20:36
CraigHickman
Posts: n/a
My reason for preferring this is all resource and weight driven. If my team actually lets me build ones of these (which I doubt will happen...), then I want to save on machining costs and weight as much as possible. That's the real motive behind this.
Unread 20-08-2007, 08:20
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
648 did the two gearbox setup this year, and had some power to spare, however , no reduction was made through gears. The twin small CIMs came up through the mounting plate with a small pulley on each. Then a timing belt serpentined throughout the pair and one other pulley gave power to each of the individual crab modules. This pulley gave power to a pair of bevel gears, then went through a final reduction through a chain drive to the wheels, giving us a final reduction of 9:1. To be honest however, I was incredibly impressed by the setup on the 118 bot. how many motors did you guys use in that one, If I remember right, you had two small CIMS, to big CIMs, and the FPs? One thing eluded me however, why did you use two pots to tell the angle of the wheels? It seems to me it would have been quicker and easier to use something like this Miniature Absolute Magnetic
Shaft Encoder
After the season was over, we wanted to see just how powerful the swerve drive was, so one of the biggest/strongest kids on the team tried to shove the robot around, and the robot ended up pushing him backwards without a problem.
Thanks
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 21-08-2007, 00:21
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Looks nice. It reminds me of the V6. So you arreee thinking about making a drive system with a central power house! Good luck.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 06-09-2007, 11:17
robostangs548's Avatar
Happy Birthday! robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Looks pretty powerfull, but heavy.... Looks good though. Nice cad, and sick gear box. Nice It would definitally put up a fight against the new AndyMark Super Shifters, (those look sweet, but i can already feel them "shifting" the money out of our teams bank account, if you know what I mean.) Nice, I would love to see it in action!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 10-10-2007, 01:38
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
hmmm
comment...
you're amazing!!!
for no reason you design a massive 4 motor gear box....
it is just so simply... first-like
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 10-10-2007, 13:08
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Originally Posted by pakratt1991 View Post
hmmm
comment...
you're amazing!!!
Well, there's always a reason to CAD something like this. It's so if the team decides to use something like this, they don't have to take the time during build season to design it.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 10-10-2007, 13:14
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Good point, in that case, I should probably get back to work on my 4 CIM, 2 Minibike, 2 Globe, 2 Fischer Price, and 18 servo gearbox. Wait, you say 118 beat me to it? sheesh.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-10-2007, 13:44
...if the team decides to use something like this, they don't have to take the time during build season to design it.
Be sure to check the rules before you use existing plans for a custom assembly. The 2007 manual contained this surprising nugget:
Originally Posted by 8.3.3 Fabrication Schedule
...completing detailed dimensioned drawings of parts, and any actual fabrication of any hardware items intended to go on the actual competition ROBOT is prohibited outside of the approved fabrication periods.
Window Motor Cad peaseonearth Inventor 15 31-01-2007 21:56
pic: 114 Gearbox CAD CraigHickman Extra Discussion 7 26-01-2007 23:37
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing jfelser Extra Discussion 24 18-12-2006 21:18
Team 33's 2004 gearbox CAD files AdamHeard Inventor 1 03-10-2006 19:07
