Go to Post Please forgive any possible profound language. - PortugazD.Ace [more]
Unread 14-10-2007, 10:11
Gdeaver Gdeaver is offline
FRC #1640
Re: GPS with VEX
I believe Easy-C pro does support serial. The functions are there but may not be exposed. I don't have Easy-C pro. Maybe some one could cjhme in or post a question in the easy-c pro sub forum.
Unread 14-10-2007, 17:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: GPS with VEX
WPILib is the framework written by Brad Miller at WPI (hence the name) from which EasyC is based on. You can program using WPIlib in either EasyC PRO (because it supports custom .c files and has a built-in text editor) or any other IDE of your choice. (MPLab, Eclipse, etc). Every time you use something like StartUltrasonic(); or SetPWM(); in EasyC, that's really a WPILib function.
There are currently 2 serial ports on the Vex controller - the RxTx port and the programming port. Using WPILib, you can interface with TTL devices (like the CMUcam) using the RxTx port and a TTL converter. As long as the device is 5v and outputs TTL, you should be able to write your own custom 'drivers' to read the signal on the Vex controller using WPILib.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-10-2007, 19:40
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: GPS with VEX
doesn't the parrallax gps have i2c, i think this would be compatible with Vex
Unread 15-10-2007, 16:08
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: GPS with VEX
How accurate would GPS be? Would it be accurate enough to detect robot movement on the field?
This made me think (kinda unrelated), but what if you set up a local positioning system within the venue to track your robot on the field (I can already think of the rules that this violates), but maybe we could ask for an exception for a completely automated system, or better yet and IFI supported venue device that is universal and could be used by all teams to track their robots?
Thinking aloud,
Jacob
Unread 15-10-2007, 16:58
Emily Horsman
Re: GPS with VEX
gps is accurate enough that you could pinpoint the location of your robot in your room (i.e. what room its in)
Unread 15-10-2007, 17:05
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: GPS with VEX
You would need easyC Pro to access the serial port to use GPS. I think GPS would be a really cool field positioning device for both FRC or FTC. I just don't know enough about how you could create your own field based GPS network. Would be cheaper to use ZigBee modules to pinpoint a location based on signal strength?
doesn't the parallax gps have i2c, i think this would be compatible with Vex
Unfortunately IFI didn't bring out I2C in the VEX controller other then it is used by the two PICs
to communicate with each other.
Unread 16-10-2007, 08:14
Emily Horsman
Re: GPS with VEX
doesnt matter, you can use standard I/O pins and make subroutines for i2c, look at this topic in the VexForum (www.vexforum.com), i've already posted how, after FIRST i'll even make the subroutines
Unread 15-10-2007, 17:27
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: GPS with VEX
maybe what room its in, most GPS units I know are accurate to only about 10-20 feet of so.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 15-10-2007, 17:37
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: GPS with VEX
It's worth noting that the quality of your GPS signal is substantially deteriorated if you don't actually have line-of-sight to the sky, so even with an exceptionally accurate GPS unit (some models have sub-meter resolution, though most likely not within the FIRST expense rules), it'd be pretty hard to ascertain your position inside an arena. However, making an outdoor robot with a GPS is pretty sweet.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-10-2007, 19:14
AKA: Jacob Komar
Re: GPS with VEX
So.... what are the odds of IFI issuing some kind of field positioning system (weather its a beacon in the center of the field, or some kind of magic sensors under the carpet) and the devices to use in our bots?
I think that while the lights are a challenge, they simply aren't accurate enough. Imagine how much more complicated the game could be if you could reliably know where your robot is at all times.
Jacob
Unread 15-10-2007, 20:14
AdamHeard's Avatar
Lead Mentor
Re: GPS with VEX
Jacob
In 2004 there were two infrared beacons that could be used.... From what I remember, most teams didn't because dead reckoning, line following & gyro and/or encoders all worked better. Anyone with more experience care to clarify?
How is the light not accurate enough though? Between this year and last year we had distance down to less than a foot of accuracy, and the angle wasn't too bad either (I don't remember exactly). I can't imagine any field based navigation being any more accurate.
EDIT: didn't realize you were talking about the entire field, not just an object...... In that case, I can't think of any current system that is realistic for FIRST that will work here....
Unread 15-10-2007, 20:20
AKA: Jacob Komar
Re: GPS with VEX
I was thinking about a radio transmission system that works like a local GPS, where something above the field is transmitting a signal, and devices on the robots can use the exact timing of that signal to determine exactly where it is (think thats how GPS works, but i could be completely wrong.) Something radio, wireless, free of looking for visual things (or infrared, basically free of line of sight stuff.) More of an actual location instead of an estimated calculated location. Think of the possibilities for a game and the autonomy of a game if you had this data reliably!
(I just realized that I'm talking about FRC here, and the thread is titled VEX. Sorry for the confusion.)
Jacob
Unread 15-10-2007, 21:05
dtengineering's Avatar
AKA: Jason Brett
Re: GPS with VEX
Here's a couple ideas to kick around... rather than using a radio signal, why not an ultrasonic signal? Since sound travels more slowly, it is a bit easier to measure the timing differences accurately. If there were four transmitters (one in each corner of the field) and each fired a slightly different length of noise at a pre-defined interval, it may be possible for the robot to determine its position with a fair bit of precision... barring reflections and other nastiness.
Or take a couple of CMUcams (or perhaps something with a bit higher resolution) and point them up at the ceiling... use some of the fixed field lighting as "stars" for an "astonomical" positioning system. It would require a fair bit of effort to deal with blinking and moving lights and such, let alone lens flares and other real-world weirdness, but in the happy, happy world of pure theory... it might work.
But anyways, that is off the point of the thread... my Garmin Etrex Legend has an RS-232 port and should be able to "talk" to a VEX. Although I've only used it for downloading track logs and uploading maps, I believe it IS capable of doing a real-time GPS location feed. The downside is that it has an older chipset... I've found the new SirfStar III devices to have much faster acquisition times and better reception. Some of them even work indoors.
There are also neat tricks for improving GPS accuracy. One of the less expen sive ones... although not a particularly useful one for real-time robotics applications... is to leave your GPS sitting in one place for an hour or so and record all the positional readings (they will fluctuate a bit). Then you compare them to the readings of a nearby receiver at a known location. Since some of the errors in your signal are caused by random atmospheric fluctuations, and since a nearby receiver will have similar fluctuations, then the errors between the two sets of readings should be similar. Since the reference receiver is at a known location, it will be possible to determine a known error, and modify the results for the mobile GPS unit. I suppose this technique could be modified to offer real-time benefits, but I don't know if I'd want to do that on a VEX platform.
Jason
Unread 16-10-2007, 11:08
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: GPS with VEX
Jason
WAAS (wide area augmentation system) does this for you on relatively new GPS receivers. it takes what the satellites are giving and compares it to a known location (WAAS station)
Unread 15-10-2007, 21:16
FRC #1640
Re: GPS with VEX
There are six fixed position 900 mhz transmitters at the operator stations. There are ways to resolve your position from these sources, however it is not easy. In the past our team has used parts of the field as way points. This proved very easy to do in stack attack and raising the bar. First put lines on the field. They where easy to detect with the Banner sensors. We drove toward the line using dead reconing, stopped when the line was detected, timed turn and go on. It was good enough to nock the ball off in raising the bar. We now have a large inventory of available senors. Each year evaluate the field for waypoints objects.
Using a VEX Receiver with Non-Vex Equipment akaria VEX 26 06-09-2008 00:55
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
Car GPS Systems KTorak Chit-Chat 10 17-11-2005 04:12
InfraRed = gps ? nzj1 General Forum 17 11-01-2004 16:58
GPS Robot K. Skontrianos General Forum 3 11-05-2002 00:32
