Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 13-10-2007, 16:37
dasmoenator dasmoenator is offline
dasmoenator is an unknown quantity at this point
Send a message via AIM to dasmoenator Send a message via MSN to dasmoenator
GPS with VEX
As of now I have a pretty complex Vex bot with a variety of sensors. I'm interested in using a GPS receiver but I'm unsure if it'll work and how I'll be able to use it. I want to be able to use the GPS receiver to control the bot to move where I want it to go. The bot also uses ultrasonic sensors to avoid obstacles if that makes if a difference. I'd prefer to not have to buy a new microcontroller if the VEX controller can do the job. But if you're 100% it can't then I'd be interested in another Microcontroller. For programming I use EasyC and RobotC.
Any input would be greatly appreciated.
Thanks
Unread 13-10-2007, 17:14
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: GPS with VEX
GPS reccivers traditionally output NMEA 0183 sets of data over a serial port. I'm sure you could decode the data and read it using a vex controller. A good overview of the output of a recciver is Here
Unread 13-10-2007, 17:17
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Re: GPS with VEX
I don't know if the Vex controler can support serial communication because I've never used vex before, but there is a a good gps reciver at http://www.parallax.com/detail.asp?product_id=28146 . I know my team was contemplating using this for our frc bot. If the vex controler does support serial communication then you just have to write some protocol code for the reciver and you shouldent have any problems.
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
Unread 13-10-2007, 17:20
Re: GPS with VEX
Yea I've been reading up on NMEA over the past few days. I was looking at this GPS reciever http://www.parallax.com/detail.asp?product_id=28146 but I was unsure if the VEX controller would be able to decode the input to be able to control the robot. I talked to a sales rep from Parallax and he was unsure as well.
Unread 13-10-2007, 19:47
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: GPS with VEX
People have used the CMUcam with a Vex controller over serial so you can defientely do it.
Unread 13-10-2007, 19:53
Gdeaver Gdeaver is offline
FRC #1640
Re: GPS with VEX
The Vex controller has 2 serial ports available. The port 2 is unused and could be used to interface to the GPS unit. It is a 5 volt TTL serial port. The Parallax GPS is 5 volt TTL and would be compatible with the Vex port. I don't remember there being serial port support in easy C however WPLib does support serial if you want to use Easy-c. Note that this an older GPS unit and probably will not work well indoors.
Unread 14-10-2007, 09:47
Re: GPS with VEX
The Vex microcontroller only has 1 serial port that I can see. But the Parallax GPS reciever, from what I can see, works with the board ports and I'd be plugging it into the rx port I assume. I guess my main problem now would be how to code it since EasyC would most likely not work. Not exactly sure what WPLib is but I also do have Carnegie Mellon's RobotC. If you could elaborate more or maybe hit me up on AIM or something that would be great.
I also noticed another good GPS unit thats being used a lot called the eTrex made by Garmin. I'd most likely need a new microcontroller which isn't the biggest problem in the world though I'd like to stay with VEX because I already have all my sensors coded and hooked up the way I want them. But the GPS at this point is more important and I'd be willing to make a change if neccessary.
Unread 14-10-2007, 10:11
FRC #1640
Re: GPS with VEX
I believe Easy-C pro does support serial. The functions are there but may not be exposed. I don't have Easy-C pro. Maybe some one could cjhme in or post a question in the easy-c pro sub forum.
Unread 14-10-2007, 17:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: GPS with VEX
WPILib is the framework written by Brad Miller at WPI (hence the name) from which EasyC is based on. You can program using WPIlib in either EasyC PRO (because it supports custom .c files and has a built-in text editor) or any other IDE of your choice. (MPLab, Eclipse, etc). Every time you use something like StartUltrasonic(); or SetPWM(); in EasyC, that's really a WPILib function.
There are currently 2 serial ports on the Vex controller - the RxTx port and the programming port. Using WPILib, you can interface with TTL devices (like the CMUcam) using the RxTx port and a TTL converter. As long as the device is 5v and outputs TTL, you should be able to write your own custom 'drivers' to read the signal on the Vex controller using WPILib.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-10-2007, 19:40
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: GPS with VEX
doesn't the parrallax gps have i2c, i think this would be compatible with Vex
Unread 15-10-2007, 16:08
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: GPS with VEX
How accurate would GPS be? Would it be accurate enough to detect robot movement on the field?
This made me think (kinda unrelated), but what if you set up a local positioning system within the venue to track your robot on the field (I can already think of the rules that this violates), but maybe we could ask for an exception for a completely automated system, or better yet and IFI supported venue device that is universal and could be used by all teams to track their robots?
Thinking aloud,
Jacob
Unread 15-10-2007, 16:58
Emily Horsman
Re: GPS with VEX
gps is accurate enough that you could pinpoint the location of your robot in your room (i.e. what room its in)
Unread 15-10-2007, 17:05
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: GPS with VEX
You would need easyC Pro to access the serial port to use GPS. I think GPS would be a really cool field positioning device for both FRC or FTC. I just don't know enough about how you could create your own field based GPS network. Would be cheaper to use ZigBee modules to pinpoint a location based on signal strength?
doesn't the parallax gps have i2c, i think this would be compatible with Vex
Unfortunately IFI didn't bring out I2C in the VEX controller other then it is used by the two PICs
to communicate with each other.
Unread 15-10-2007, 17:27
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: GPS with VEX
maybe what room its in, most GPS units I know are accurate to only about 10-20 feet of so.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 15-10-2007, 17:37
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: GPS with VEX
It's worth noting that the quality of your GPS signal is substantially deteriorated if you don't actually have line-of-sight to the sky, so even with an exceptionally accurate GPS unit (some models have sub-meter resolution, though most likely not within the FIRST expense rules), it'd be pretty hard to ascertain your position inside an arena. However, making an outdoor robot with a GPS is pretty sweet.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Using a VEX Receiver with Non-Vex Equipment akaria VEX 26 06-09-2008 00:55
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
Car GPS Systems KTorak Chit-Chat 10 17-11-2005 04:12
InfraRed = gps ? nzj1 General Forum 17 11-01-2004 16:58
GPS Robot K. Skontrianos General Forum 3 11-05-2002 00:32
