Go to Post But then again, no one's robot ever is fully working to how they want it before the first tournamant. - #1Transgirl1140 [more]
Unread 15-10-2007, 13:53
tubeheaD37 tubeheaD37 is offline
FRC #2079
tubeheaD37 is on a distinguished road
Automatic Block Counteraction Program
My team has been discussing options for how to automatically counteract blocks and hits so that the driver can control relative to 0 speed rather than 0 power to the motors. Options including a trackball method, perpendicularly arranged smart wheels attached to small generators, and accelerometers in order to determine the movement of the robot automatically at any given time have been put on the table. Has anyone ever tried anything similar? If yes, how did it work? If no, why not? Does anyone have any other ideas about how we could determine the actual movement of the robot?
Unread 15-10-2007, 14:58
Re: Automatic Block Counteraction Program
The usual way to do this is to put rotary shaft encoders on the drivetrain. Sometimes they're connected directly to the gearbox, sometimes they're driven by an extra sprocket on the chain powering the wheels, and sometimes they're on a "follower" wheel that rides on the carpet. The electrical output from a typical shaft encoder is a pair of digital signals that change in sequence to indicate both speed and direction of rotation. Search the ChiefDelphi forums for "encoder" if you want to find more information, and ask again when you have specific questions.
(The AndyMark Super Shifter has a built-in spot for such a device on the output shaft.)
Automatic Transmission gnirts Programming 6 18-01-2007 20:44
Automatic Power Swampcoder2 Control System 6 03-02-2005 17:08
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
automatic archiving Joe Ross CD Forum Support 5 04-08-2003 13:27
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
