Go to Post 22 motors? Challenge Accepted. - gyroscopeRaptor [more]
Unread 15-10-2007, 18:51
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
RS-232 GPS on RC?
We're looking at hooking up a Garmin GPS that outputs in RS-232 to our prog port and getting the coordinate data from the NMEA 0183 standard output. How would we go about recieving this data from the prog port?
Unread 15-10-2007, 19:00
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: RS-232 GPS on RC?
Take a look at Kevin Watson's serial port driver
www.kevin.org/frc
All you would have to do is match the baud rate, and then just make a state machine to read in the bytes coming from the gps
Unread 15-10-2007, 22:59
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Its definitely possible. I experimented over the summer with just using my desktop pc to test the possibilities of using an offboard coprocessor. I just hooked up the camera to the rc and loaded some serial code onto it and I managed to make the camera pan and tilt when I moved the joystick. That may not seem like much but it was the fact that my pc was doing all the work that proved that the serial communication worked. If you managed to get a data sheet for your gps unit that includes baud rate and the structure of the data packet you could definitely get it up and running. Just remember that your reception may vary and that some units take a while to find satellites.
-Don
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
RS 232 and Dashboard Jake M Programming 6 06-03-2007 17:52
RS-232 Programming port as an active interface Goose Programming 1 03-04-2005 15:40
TTL -> RS-232 Board won't stay on! Mr. Lim Control System 5 16-02-2005 11:29
TTL -> RS-232 Board won't stay on! Mr. Lim Electrical 5 16-02-2005 11:29
RS-232 TTL Board? Sidney San Martín Electrical 8 08-01-2005 22:46
