Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
Unread 16-10-2007, 08:43
Kettering's Avatar
Kettering Kettering is offline
read. set. rebound rumble.
AKA: Steve Smitka
FRC #3098 (The Captains)
Kettering is just really niceKettering is just really niceKettering is just really niceKettering is just really niceKettering is just really nice
Question Radio sos
I know this is very vague, but our robot is having issues recieving a signal from the control board through the radio, though it works just fine through the tether. The wiring seems correct, so would anyone know what the problem might be with the hardware (including settings)?
Unread 16-10-2007, 09:15
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Radio sos
The 2007 radios are notorious for working poorly
Unread 16-10-2007, 09:18
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Radio sos
try workin with the 2006 radios...they are great...
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 16-10-2007, 09:30
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Radio sos
#1: make sure the radios match. EG.. both 2007 or both 2006
#2: try new/different cables
#3: call IFI - be ready to tell them the color and state of the No Data/Radio LED
Unread 16-10-2007, 09:44
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Radio sos
A common problem is really simple to solve.
Make sure the RC radio is on the RC, and the OI radio is on the OI.
Sometimes they get swapped and nothing work.
Ed Barker
Unread 16-10-2007, 09:55
Re: Radio sos
Can you be more specific about what "having issues" means?
In addition to the obvious metal antenna, the 2007 radios have another antenna hidden inside the case. Make sure that antenna isn't buried behind a chunk of metal.
Have you checked for radio interference? Some cell phones (the GSM variety, I think) have shown the ability to mess with robot communication if they're too close to the OI. If you have a 900 MHz cordless phone, wireless security system, or audio/video extender system, that might be causing problems. Try setting your radio to channel 04 or 13 instead of 40.
Unread 16-10-2007, 10:53
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
Re: Radio sos
If this is the same as the OCCRA forum the radio bieng used is a 2004 I believe.
Unread 16-10-2007, 13:58
Kettering's Avatar
AKA: Steve Smitka
Re: Radio sos
To be more specific, our controls work properly when the bot is tethered. When we try to control it through radio transmission there is no signal. The obvious answer is that our transmitters arent working properly. But we have tried several transmitters and nothing has worked. Also the rc says that the radio transmission is working fine yet the actual transmitors remain on standby
Unread 16-10-2007, 14:38
MWTrek's Avatar
MWTrek MWTrek is offline
AKA: Matt Willett
FRC #3597 (Robo-Rangers)
MWTrek is a glorious beacon of lightMWTrek is a glorious beacon of lightMWTrek is a glorious beacon of lightMWTrek is a glorious beacon of lightMWTrek is a glorious beacon of light
Send a message via AIM to MWTrek
Re: Radio sos
Something like this happened to us at Bash at the Beach. We were out two matches. We worked properly for about 5 secs and then lost radio signal. The on hand FIRST rep took a look at it. No one could figure out what the problem was. We took the robot out onto the field to diagnose the problem after the quals and it seemed to work fine. It was strange.
Robo-Rangers
R.W. Traip Academy- Kittery, ME
3597
Aces High 2004-2008
Windsor Locks/Suffield
176
Unread 16-10-2007, 15:08
Kettering's Avatar
AKA: Steve Smitka
Post Re: Radio sos
How can I be sure if we have the correct transmitter? Like, how do I know if they are the same year and which goes to the OI and which goes to the RC?
Unread 16-10-2007, 15:10
Re: Radio sos
How are you determining that "there is no signal"? What makes it obvious that the fault lies in the transmitters rather than in a receiver?
What year's OI, RC, and radios are you using? What version of the RC master code is loaded?
Please describe for us exactly what you have plugged in to each 9-pin connector, including the cables in the detailed description. Tell us what switches you're flipping, and in what order. Let us know what indicators are lit on the OI, both radio modems, and the RC. Try not to gloss over anything in an attempt to make it easier for us to understand. Without the actual specifics of what's happening, it's very hard to tease out what might be the problem just by reading your interpretation of the situation.
Unread 16-10-2007, 15:24
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Radio sos
We had a problem like this very recently.
All it took was switching out a serial cable. Our OI and both radios said there was no signal.
You mentioned that the RC says it's working. I may be wrong on this part, but working would mean that all lights are lit green. Is this the case? When we had radio issues (which turned out to be a serial cable issue) the "Radio Modem" light was orange.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 16-10-2007, 18:34
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: Radio sos
I am closing this thread as this is a OCCRA (Oakland County Competitive Robotics Association) issue using older IFI controls.
Mike Martus
Ham Radio and Radio at FIRST bcieslak General Forum 41 06-04-2007 10:41
SOS RDD Programming 3 14-02-2007 12:24
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
FM radio transmitter Alexander McGee Electrical 11 29-10-2003 19:41
Amateur Radio ckim Chit-Chat 1 02-01-2003 22:36
