Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 16-10-2007, 14:56
Re: four wheel drive
Unless you need to control the front and rear motor speed separately on each side, there's no difference in either programming or wiring between what you're doing and a standard tank drive system with two motors in tandem on each side.
If you do want individual control of each motor...why? And how do you plan to give the driver that control?
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Four Wheel Drive Using Standard Transmissions daviamp Technical Discussion 4 18-01-2006 20:03
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Four wheel drive question haverfordfords General Forum 25 25-01-2005 23:24
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
