Go to Post why re-invent the wheel when it still rolls? just make it better. - Tytus Gerrish [more]
Unread 16-10-2007, 19:45
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Code To Make The Radio Work
I have a robot with a 2004 RC and IO, but they are not communicating. The IO radio is transmitting but the RC radio is only on standby. We did a master reset but did not solve or problems. I was wonder if there was code that controlled the radio? When I tethered the robot, it work perfectly well! This is something that I never seen. Please Help! Thank You!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 16-10-2007, 20:25
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Code To Make The Radio Work
Try swapping the cable out on the radio. Sometimes they get flakey, especially with old age.
Unread 16-10-2007, 20:49
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
I have switch the cables.
Team 842 Programmer
Pictures at:
Videos -
Unread 17-10-2007, 09:38
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
sounds like the 2007 radio problems. Make sure you have older radios.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 17-10-2007, 09:40
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
I the radios are 04 radios,
Do you think it is a hardware or software problem?
Team 842 Programmer
Pictures at:
Videos -
Unread 17-10-2007, 09:48
The code that controls the radio is in the master CPU. You say you're using a 2004 control system, but are the radio modems also from 2004? In order for the RC to work properly with the 2007 radios, make sure you've got version 15 of the master code loaded. For earlier radios, version 13 should be sufficient, but version 15 is still preferred.
Have you checked for possible sources of radio interference?
Unread 17-10-2007, 16:02
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
I reloaded the master code but still some results.
Any More Ideas?
Team 842 Programmer
Pictures at:
Videos -
Unread 17-10-2007, 20:41
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Have you tried using the OI interface from 2004 with the RC interface from 2004? If this works, your hardware is not the issue and both are working fine.
2005,2006 hardware are compatible with each other, but when you try to use or mix them with 2007 hardware, they will require the firmware changes talked about earlier, but the communication is still not flawless because the hardware is not 100% compatible. You may have to purchase a 2007 replacement radio for the one that is failing.
I hope this helps.
Team MARS = 1.523 AU from the SUN!
Jim E.
Make your CAM2 work great! pafwl General Forum 0 06-04-2007 22:12
CANT GET THE CANERA CODE TO WORK!!!! plz HELP!! its da PAT!!! Programming 3 18-02-2007 23:07
Steps to make cam work? magical hands Programming 7 31-01-2006 17:43
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
How to Make MS joystick work/has anyone used it in past? andhesayz Control System 25 17-01-2005 10:34
