Go to Post Batteries are like clamps or money, you can never have enough. - IndySam [more]
Unread 18-10-2007, 12:21
et1337's Avatar
et1337 et1337 is offline
et1337
AKA: Evan Todd
FRC #1317 (Digital Fusion)
et1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of light
Arrow MCC18 Installer Script
I'm working on a sort of cross-platform development server, like a software repository and compiler service bundled together to work with a thin client.
Anyway, I just got MCC18 working on my Ubuntu installation, and it was too painful to be worth it.
So I'm wondering if it's possible to make some scripts/installers for Linux that can automagically install MCC18. Meaning, the user pops in the MPLAB CD, the script finds the MCC18 folder, copies the files over to /opt/mcc18, fixes p18cxxx.h (per this post) and maybe offers an option to install WINE.
Is this feasible? I am by no means an experienced Linux user, so I wouldn't know where to start.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.
et1337
Unread 18-10-2007, 13:00
Re: MCC18 Installer Script
You could write a bash script.
http://www.panix.com/~elflord/unix/bash-tute.html
http://tldp.org/HOWTO/Bash-Prog-Intro-HOWTO.html
www.google.com
Unread 18-10-2007, 14:39
et1337's Avatar
et1337
AKA: Evan Todd
How would I get it to install WINE or XAMPP? Also, how would I make it read from the CD drive?
et1337
Unread 18-10-2007, 15:27
The cdrom drive gets mounted at "/cdrom" in ubuntu. So you can copy files with something like this
sudo cp -r /cdrom/(mcc18 folder) /opt/mcc18
I believe opt requires root access to write to, so you will need to use the sudo command.
You can use apt to download and install wine and apache. Google apt commands.
Unread 18-10-2007, 15:38
et1337's Avatar
et1337
AKA: Evan Todd
Right, I've used apt plenty of times. So I can just put a "sudo apt-get" call in the script and it will install? Sweet.
Sorry, I've never written a linux script, obviously.
et1337
Unread 18-10-2007, 15:46
I've never actually tried it before, but when the shell runs a script it will run all of the commands as if you had typed them in, so it should work fine. Let us know when you finish this.. it will be a great tool for those of us who develop on Linux.
Unread 21-10-2007, 01:27
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
I don't know what your procedure was, but I didn't have any problems on Fedora. I just copied C:\MCC18 from a windows installation. WINE was already installed and the compiler it just worked. I'm using piklab for my own projects though. I haven't tried it with the robot code.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
MCC18 C compiler 60 day grace window Japper Programming 4 21-02-2007 07:24
Variadic functions with mcc18 schroedinbug Programming 4 19-02-2007 00:51
Known Bug With mcc18 and Wine 0.9.22 ScottWalls Programming 1 05-11-2006 15:03
Using MCC18 in a custom program EHaskins Programming 15 25-04-2006 23:35
Napster Installer Wanted MattK Chit-Chat 2 12-11-2002 20:43
