Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 20-10-2007, 19:07
BlackShadowFox's Avatar
BlackShadowFox BlackShadowFox is offline
AKA: Madwolvez
FRC #0401
Team Role: Electrical
BlackShadowFox has a spectacular aura aboutBlackShadowFox has a spectacular aura about
Send a message via AIM to BlackShadowFox
Electronics Boards Designs/Ideas
This post is for teams who would like to post ideas about electronics board designs (Images) and ideas about them. You may show current, past ,and even future boards. Ideas can be from connectors to charging circuits it doesn't matter. This page is also to help new and old teams in design issues.
Please post as much as you can i will hold no secrets from you and show you my plans as soon as they are approved.
Note: Please Don't post things multiple times
Unread 20-10-2007, 20:29
AKA: Madwolvez
FRC #0401
Re: Electronics Boards Designs/Ideas
Well Now that i Have approval here is my design
size 13x10x3ish
8 victors
The fuses are mounted up sided down this allows you to remove the fuses without bending or disconnecting any wires. It also has what i call the stupid act which means no one can drop something inside or cross anything with their hands allowing for a safer board. This board also is set up to have the victors blow air over the internals to keep them cooler and last longer.
note I'm aware that the distribution block has yet to be added but space is provided for it.
Unread 21-10-2007, 04:12
Arille's Avatar
Arille Arille is offline
FRC #2135
Arille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to behold
Send a message via AIM to Arille
Nice design!
Would the two polycarbnate pieces be attached in any way, or is the top piece simply just lying on top? (resting on the fuses, I'm guessing) I would think it would be somewhat of a nuissance if the two pieces of polycarbonate were indeed screwed/attached together somehow, or else it wouldn't be easy access to get to the fuses OR the victors..
I can just imagine the mayhem of wires going through this baby. Beauuutiful
Team 2135: Presentation Invasion
Silicon Valley Regional 2007 Rookie Inspiration Award!
Unread 21-10-2007, 11:04
AKA: Madwolvez
FRC #0401
There would be 4 supporting pillars that would attach the two boards but i wanted to wait until i could import the distribution block in to inventor 7 to see their placement.
But your are right the wiring would be hard and require a day or two.
Unread 21-10-2007, 16:19
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
10 vics
4 spikes
14.5x10.5x2.5
http://www.flickr.com/photos/15636395@N06/1677872578/
Unread 21-10-2007, 16:26
AKA: Madwolvez
FRC #0401
nice board, but where is your controller?
a little bit cramp but still a great looking board.
Unread 21-10-2007, 22:50
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
WOW, i look at all the designs and they are amazing. My boards don't look like that, don't get me wrong my boards look very very neats and everything is arranged in the optimal positions, but what you guys do is just artwork.
Championship - Delphi "Driving Tomorrows Technology"
Unread 22-10-2007, 17:49
ADZDEBLICK's Avatar
Originally i had the controller mounted above the fuses, but i took the controller off so it could be mounted separately. This would make it easier to change fuses and to wire neatly. I could always turn the board upside down and mount the controller on the bottom (which would then be the top)
Unread 23-10-2007, 12:42
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Originally Posted by ADZDEBLICK View Post
Terribly overcramped, but that's a worse-case scenario with 10 victors. I think most teams could get away with 6ish victors depending on the manipulator. I never really thought about separating the RC from the rest of the Electronics board, that's not a bad idea considering 1885 is think up new frame concepts right now. The hardest part has always been the eBoard, battery & compressor mounts.
GitHub
Unread 23-10-2007, 18:10
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
how do you make your electronics board?
just keep programming the same old thing every time over and over and over....
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Camera Boards Inoperational Programming 6 20-01-2007 12:57
OI Boards? Jake M Robot Showcase 1 28-11-2006 20:02
pic: Team 254 Electronics Boards Cory Robot Showcase 15 20-02-2006 22:48
Pros and cons of electronics boards/boxes RbtGal1351 Electrical 19 20-11-2005 15:01
Control Boards tenfour General Forum 3 01-03-2004 20:01
