Go to Post You can't guarantee outcomes -- only effort. If your team did its best, be satisfied. - Rick TYler [more]
Unread 22-10-2007, 12:35
mmqpz mmqpz is offline
mmqpz is an unknown quantity at this point
reflected inertia
How can I explain why a gear ratio reduces the inertia by the gear ratio squared? I do not understand why it is squared.
Thanks
Unread 22-10-2007, 13:18
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: reflected inertia
http://www.racer.nl/tech/effinertia.htm
Unread 22-10-2007, 14:18
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Tom Line View Post
The link above is a nice explanation.
Concisely, the square in the formula for reflected inertia comes from one simple observation: when frictional losses in the gearing are neglected, kinetic energy must be the same when observed on either the high-speed shaft or the low-speed shaft.
For a rotating system, KE = 0.5 * J * w^2, where J is moment of inertia and w is angular velocity.
So to make observed KE equal on two shafts coupled through a geartrain with speed ratio (w2/w1), J1/J2 must equal (w2/w1)^2.
[Using SI units we would express w in rad/sec, J in kg-m^2 or Joule-sec^2, and KE in Joule.]
As an example: a 50cm diameter steel flywheel 10 cm thick has about 5 Joule-sec^2 moment of inertia. When it spins at one rad/sec its kinetic energy is about 2.5 Joule. If we couple this flywheel to a 10:1 gearbox the shaft on the other side will spin at 10 rad/sec, the kinetic energy measured on the high-speed shaft will still be about 2.5 Joule, and the inertia of the flywheel reflected to the high-speed shaft will be about 0.05 Joule-sec^2.
Richard Wallace
since 2003
Unread 22-10-2007, 14:46
Thanks to both of you. Your responses helped greatly.
Inertia Guidance System Venkatesh Technical Discussion 2 12-01-2003 01:37
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
