Go to Post You can't unwind after build season knowing that competition season is just around the corner! ;) - Hallry [more]
Unread 22-10-2007, 19:23
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Operator Interface Troubleshooting
That's a good thought, but I know at least one Victor is functioning correctly because the motor does turn, but I assumed it was just turning because it wasn't calibrated correctly (or the trim is off). It does not vary with time or any change in the controls. And again, the joystick was also hooked up to a servo which won't move. Also, I neglected to mention that I also coded it to turn one of the relay led's to green when the trigger switched was clicked, and nothing happened.
operator interface carbuff Rules/Strategy 1 18-02-2007 09:06
operator interface tml240 Electrical 5 10-02-2004 17:50
Operator Interface Heads Up Madison Robotics Education and Curriculum 6 11-12-2002 06:59
operator interface board archiver 2001 4 24-06-2002 00:33
