Go to Post A few years of stress is worth a lifetime of opportunity. - omegasis25 [more]
Unread 17-10-2007, 17:50
u2andllamasohmy's Avatar
u2andllamasohmy u2andllamasohmy is offline
FRC #0701
u2andllamasohmy is an unknown quantity at this point
Question info on 997 bot or 254 bot please!
Hi my name is Jason Maier of team 701. We are doing a report on impressive bots we saw at cal games. I need info on motors and gears used on these two bots. Etc. Etc.
Thanks
Unread 17-10-2007, 18:14
Colin's Avatar
Colin Colin is offline
FRC #0254
Colin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond repute
Re: info on 997 bot or 254 bot please!
Specifically what kind of information. In the drive train 254 has 2 small CIM motors geared 1:6 and 1:16 using a custom transmission based off of the Teckno Cat shifter. The transmission direct drives the center wheels of a 6 wheeled drive base with 3.75" wheels. The elevator has two Fischer Price motors, not sure on the gearing here.
Unread 17-10-2007, 18:29
AdamHeard's Avatar
Lead Mentor
Thanks
There is a lot more than what motors and gears on a 254 bot that make it impressive.
If you look through CD-media with photos tagged frc254 or frc968 there are a lot of good pics/threads about this year's (and previous year's) robots.
Unread 17-10-2007, 18:48
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
997 = tank treads (this makes it bounce around when it turns)
can push really well, IT CAN PUSH A ROBOT SIDEWAYS
it's got dual lifts, one is made from fiberglass, the other is made from carbon fiber
It uses pneumatic pistons to raise their platforms.
It's an end-game bot, but it does do defense really well.
The only problem i see with it (as an external observer) is that it has two sets of two pneumatic pistons completely exposed when their lifts are deployed. (Sorry for breaking them at Davis last year, couldn't see what the robot was doing on the other side of the rack)
Sam N.
Mitty Robotics Alumni
TKO 1351
Unread 17-10-2007, 19:02
CraigHickman
Posts: n/a
Uh, no, not really. The Outback Track system only bounces when turning in high gear, at full speed. And even then the bounce isn't that bad. Also, the bouncing has been fixed for the next revision...
Unread 22-10-2007, 23:57
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Jason,
Search the threads for "Outback" or "treads", teams that used them are 997, 753, ???
Here's one to start you off..
http://www.chiefdelphi.com/media/photos/28213
Unread 23-10-2007, 12:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm pretty sure Carbon Fiber is not a legal material.
GitHub
Unread 23-10-2007, 13:04
AdamHeard's Avatar
Lead Mentor
Carbon fiber is legal as long as it meets the cost rules.
I saw a few teams at LA/SD/Galileo that had custom molded carbon fiber ramps.
Unread 23-10-2007, 18:19
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
At one time it was specifically prohibited. However that changed several years ago as it became more readily available. There are still safety and health issues in dealing with it.
Just a reminder, always read THIS year's rules. These things do change from time to time. So what was illegal this year may not be next and vice versa.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 23-10-2007, 18:57
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
just a side note:
I was chatting with an inspector at the VCU regional last year. As a rookie team, he was doing a great job taking us under his wing and walking us through the inspection process.
One of the things he asked us was, "Did you use any exotic materials?"
After chuckling at him because almost everything we used was from the KOP, i asked, "What do mean by 'exotic'?"
He replied,"you know things like Titanium alloys and carbon fiber"
he went on to clarify that if you bought a carbon fiber golf shaft and used that on your robot that would be one thing, but a custom part would be highly suspect.
Unread 23-10-2007, 19:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by wilsonmw04 View Post
just a side note:
I'd venture to say that he didn't know what he was talking about.
--Madison--
...down at the Ozdust!
Unread 23-10-2007, 21:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
In an absolute sense, I'd agree with you. As long as you met the materials limit, you'd be fine.
I recall a discussion on here where someone (I think it was Chris, actually) mentioned that he had considered making some carbon fiber parts, but the only way he could get the resin to make the parts with was in 55 gallon drums that cost some ridiculously expensive amount. Even though he obviously wasn't going to use all 55 gallons of resin, since that was the smallest quantity commercially available, he'd have had to account for the entire 55 gallons, not a prorated portion.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-10-2007, 23:02
Doug G's Avatar
Coach / Teacher
As long as you account for the items and they qualify as COTS it is perfectly legal under the 2007 rules. We used West Coast Systems Epoxy, Hardener, some lightweight foam, and the carbon fiber cloth of course. You can find West Coast brand in many high end hobby stores and on-line, ours came in 1 gallon jugs with pump dispensers.
Here's a pic of our layup with the vacuum bag and cooker (heat gun suspended from above)...
Unread 23-10-2007, 23:10
Brandon Holley's Avatar
can i just say, what the heck is going on in this thread?? i am lost
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 24-10-2007, 00:10
Information was requested about two robots. Somewhere along the line, someone mentioned that one of the robots in question used carbon fiber. Someone else thought that was illegal, and the discussion turned to legality/use of carbon fiber.
Now, if we can get back on track...
pic: Team 241: This Years Bot Lifting Last Years Bot Dantvman27 Robot Showcase 3 21-02-2007 07:04
Ramp bot vs. Arm bot SSMike Technical Discussion 49 22-01-2007 21:03
bot carts. need info! 1075master General Forum 25 06-01-2006 23:16
Dr. Bot JamizzleHavok13 NASA Discussion 0 28-03-2005 14:33
S.P.A.M. 05 BOT tiffany34990 Robot Showcase 14 09-02-2005 11:04
