Go to Post You play your best, the refs do their best, and at the end of the day we are FIRST, collectively. - KenWittlief [more]
Unread 24-10-2007, 21:23
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Re: Won't Download!
Have you checked your COM port?
Go into your Device Manager (from the Start menu, click on the Control Panel and then System) and look for the "Prolific USB to serial adapter" under "Ports". This will be assigned to a COM number.
From there, open easyC and select "Loader Setup" from the Build & Download Menu. You'll find a drop down box to select your COM port. Once selected, hit OK and attempt to download again.
If this does not work I recommend trying another usb port on the PC. You want to make sure your PC recognizes the new hardware and that it tells you it is ready to use. Make sure to check the device manager, as the COM port may change each time you plug into the PC.
Alternatively, you can plug the Programming Dongle directly to the serial port (if you have one), which would default to COM1. If all else fails, feel free to send me an email or PM & we'll get you up and running ASAP.
JAB
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Robot won't go straight svanderlugt Technical Discussion 12 16-02-2007 15:20
RC won't talk to CMUcam HPA_Robotics_13 Programming 8 18-02-2005 08:38
MplaB 5.70 won't install soundman Programming 4 08-01-2005 23:02
Album won't load... Lisa Perez Website Design/Showcase 3 05-07-2004 00:41
EDU won't power up. actorindp Robotics Education and Curriculum 4 12-02-2004 22:20
