Go to Post Proof: Remove the motor from it's mechanical house of bondage and it will operate just fine - Mike Betts [more]
Unread 25-10-2007, 19:11
diaperrash89 diaperrash89 is offline
diaperrash89 is an unknown quantity at this point
Bumper Sensor Question
Hello,
We finally got our vex robots up and running and we've just done some pretty basic programming right now. So far our school has just a few sensors, bumpers being one of them. While we're just kicking off this robotics program, we're not so sure how to program the bumpers. I know how to put in the digital input and what not. Do we just have to tell the bumpers to get the digital input? Basically we want to tell it if the bumper is pushed, go the other way.. Advice? thanks.
Unread 25-10-2007, 23:09
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Bumper Sensor Question
Originally Posted by diaperrash89 View Post
Hello,
Check out the Programming section of the Vex Inventor's Manual, which is available as a PDF download from the Vex programming page at Vex Labs. This PDF is a great introduction to using Vex sensors with EasyC, and has specific examples of code that makes a robot back up if it something hits the bumper switch.
Art Dutra IV
世上无难事,只怕有心人.
Unread 26-10-2007, 06:17
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
get digital input into a variable, the variable will be an unsigned char, then if the value of the variable is 1, the button is pushed, if it is 0, it is not
Unread 26-10-2007, 06:48
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Here is a screen shot of a Limit Switch test I had done. (I'm assuming you're using easyC for Vex.) Limit Switches are the same as Bumpers, just more sensitive and less durable, and the pretty easyC icon is different. The limit variable is an int. Change Digital Input number to suit, add PrintToScreen's to test the alternate conditions, and add SetMotor's to taste.
If I remember, there was some code that, if front bumper was hit, drive motors backwards and turn left 90 degrees, else let the driver drive the motors.
And, yes, check out the Vex PDF for the full explaination. I just get impatient reading it sometimes.
Bumper Question - More like Pool Noodle bLuEpHoEnIx Technical Discussion 5 12-02-2007 21:33
bumper question math4origami Rules/Strategy 4 16-01-2007 14:47
Question about programing the bumper sensors itsme Programming 9 10-12-2006 18:03
NPN Sensor Question Mr. Steve Programming 2 17-02-2006 00:05
IR sensor question Daniel Brim Programming 1 18-01-2004 14:35
