Go to Post Overpowered? You only took out half the building... Knock the rest down then get back to me. - sodizzle [more]
Unread 26-10-2007, 06:48
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: Bumper Sensor Question
Here is a screen shot of a Limit Switch test I had done. (I'm assuming you're using easyC for Vex.) Limit Switches are the same as Bumpers, just more sensitive and less durable, and the pretty easyC icon is different. The limit variable is an int. Change Digital Input number to suit, add PrintToScreen's to test the alternate conditions, and add SetMotor's to taste.
If I remember, there was some code that, if front bumper was hit, drive motors backwards and turn left 90 degrees, else let the driver drive the motors.
And, yes, check out the Vex PDF for the full explaination. I just get impatient reading it sometimes.
Bumper Question - More like Pool Noodle bLuEpHoEnIx Technical Discussion 5 12-02-2007 21:33
bumper question math4origami Rules/Strategy 4 16-01-2007 14:47
Question about programing the bumper sensors itsme Programming 9 10-12-2006 18:03
NPN Sensor Question Mr. Steve Programming 2 17-02-2006 00:05
IR sensor question Daniel Brim Programming 1 18-01-2004 14:35
