Thread Tools |
Rating:
Display Modes |
Re: Blowing 60 Amp fuse
Posted by Allen Smith, Engineer on team #7, Knights, from Parkville High School and Black & Decker/AAI/Raytheon.
Posted on 3/20/99 2:27 PM MST In Reply to: Blowing 60 Amp fuse posted by Joe Johnson on 3/19/99 5:17 PM MST: We were your partners when you blew that fuse in the quarter-finals at Philly so I have been thinking about this problem also. First, I am amazed at the traction you get from your wheels. Do you have some secret treatment to keep them from slipping? If your wheels would slip you would of course have less pulling power but the slipping would act as a "fuse" keeping the motor operating in an acceptable region. This is what happens with our robot and we have yet to blow a fuse or burn up a speed controller. A possible solution, and I'm just speculating here and would love comments, would be to have 5 to 10 feet of coiled wire between your ground bus and your battery acting as a current monitoring shunt. Connect the ground bus that is on the far side of the coil of wire from the battery to an analog input on the controler, assuming you have a few tens of milliohms in that coil your controller should be able to sense the total current flowing and do something about it like light a warning led or cut back on the PWM signal going to the motors. It would be nice to have a filter on the signal going into the controller and a zener to clamp it to no more than 5 volts but with only kit parts I don't think this is possible. |
| Aux Fuse 3 (Yaw Rate) | Josh Hambright | Electrical | 0 | 18-02-2003 08:22 |
| picture of 40 amps fuse holder and fuse | rcubes85 | Technical Discussion | 1 | 13-02-2003 16:03 |
| 60 amp Circuit Breaker Info | archiver | 2001 | 1 | 23-06-2002 22:33 |
| how do u hook up things through the fuse panel? | chrisw | Technical Discussion | 9 | 12-01-2002 19:51 |
| Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? | Anton Abaya | Chit-Chat | 4 | 12-01-2002 14:09 |
