Go to Post well, our team isn't actually building a robot, we're covering our team leader in foil. - NERD12345 [more]
Unread 28-10-2007, 10:53
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
USB - Serial cable
Hey guys,
i am trying to get a picture from the cmucam2 using mplab to my laptop, which doesnt have serail ports, only usbs (4 of them).
i read somewhere that i need a driver of some sort...
the usb cable im using is from the vex kit, i think, and its orange, if it helps you help me =]
Thanks, im depsperate here!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 28-10-2007, 10:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: USB - Seiral cable
maybe this thread will help?
http://www.chiefdelphi.com/forums/sh...ad.php?t=46174
a real serial port does seem to work better, though. Don't you have any old computer around? (asks the guy with about 100 old computers at home)
Unread 28-10-2007, 11:25
Tottanka's Avatar
AKA: Liron Gurvitz
thanks, its ALIVE!
Unread 29-10-2007, 07:18
Tottanka's Avatar
AKA: Liron Gurvitz
ANOTHER PROBLEM:
i've downloaded kevin's whistling code to the RC, connectede the camera as said (i think), and it isnt searching for the light at all...
anyone knows what it might be?
Unread 29-10-2007, 10:26
Originally Posted by Tottanka View Post
...it isnt searching for the light at all...
It might be any one of a dozen wiring issues.
It might be that you don't have camera power applied.
It might be that you don't have the pan and tilt servos correctly connected.
It might be that you don't have a fully-charged backup battery connected.
It might be that you don't actually have the camera serial data connected properly.
It might be that you don't have the Robot Controller enabled.
It might be that you have a faulty camera board.
What is it doing? You should be able to monitor the process with a terminal window while the computer is connected to the RC's program port.
Unread 29-10-2007, 10:41
MrForbes's Avatar
AKA: Jim
yup, having a few photos showing your setup, including all the wiring connections, and maybe some screen shots, would help others help you figure it out.
Unread 29-10-2007, 14:46
Tottanka's Avatar
AKA: Liron Gurvitz
the camers is on, backup battery is good too...
it might be the wiring, though i dont thins so. pan is pwm1 tilit is pwm2, power is frome pwm16 and the ttl is connected, is that it?
The window is supposed to say search, but it doesnt...
any clue?
Unread 29-10-2007, 15:22
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
What is the LED on the camera doing?
How about when you put the green light in front of the lens?
Jacob
Unread 29-10-2007, 16:58
any clue?
At the risk of (almost) repeating myself...what does it say?
It sounds like the Robot Controller is not running the program. Are you running it tethered or via radio? What color are the status LEDs on the RC and OI?
Unread 29-10-2007, 18:06
Tottanka's Avatar
AKA: Liron Gurvitz
OK, now i've got her searching for the light, but once she finds it she doesnt stop searching, but keeps on going..
the red led doesnt turn on when she's "on" the target.
Unread 29-10-2007, 19:10
Make sure the camera lens is properly focused.
You might find most of your concerns are addressed in Kevin Watson's CMUCam2 FAQ.
Unread 30-10-2007, 01:26
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
If the red light doesnt come on the camera is not tracking it, even though its pointing at it. You might want to recalibrate your camera and get new color values.
Unread 30-10-2007, 07:27
Tottanka's Avatar
AKA: Liron Gurvitz
Re: USB - Serial cable
The camers if focused. I have calibrated her udins LabView, but it still doesnt work.
Any ideas?
Unread 30-10-2007, 12:57
Tottanka's Avatar
AKA: Liron Gurvitz
Any ideas anyone?
Unread 30-10-2007, 19:06
Back after 4 years off
FRC #5279
Any ideas anyone?
Download the CMUCam2 GUI and capture an image with the light in it. Next select the light and check to make sure that the values Y, Cr, and Cb are within the ranges you found when you calibrated the camera.
If the red light does not come on then the camera doesn't see the light, it must either be out of focus, calibrated wrong, or wired wrong.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
USB To Serial Devo1098 Programming 3 30-06-2007 19:51
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
usb to serial cable karinka13 Technical Discussion 4 10-02-2006 17:30
USB-Serial Cable + Terminal Spencer E. Programming 3 22-01-2006 12:16
Serial Cable Andrew Rudolph Technical Discussion 9 15-08-2002 22:09
