Go to Post they used the same random number generator we used for our autonomous drive code . . . (oops did I say that?) - MrForbes [more]
Go Back   Chief Delphi > Old Forum Archives > 1999
Unread 23-06-2002, 22:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Possible Rule change for Flordia? (Please) and the reason for more seeding rounds.
Posted by Jay Booth, Student on team #140 from Tyngsboro High School and Brooks Automation / New England Prototype.
Posted on 3/21/99 3:25 PM MST
In Reply to: Possible Rule change for Flordia? (Please) and the reason for more seeding rounds. posted by Mike King on 3/21/99 2:29 PM MST:
I agree that if at all possible we should have more seeding rounds for all the reasons here and those in the giagantic thread I didn't even finish about the issue. However, FIRST seems to be under the impression we'll have too many teams and not enough time. I'm sure by this point it is really hard to reschedule to competition to allow for more time. So my solution is instead of putting the top 8 into the finals with a pick, have an extra round of finals and put the top 16 in with their draft choice. It uses significantly less time than giving each team another 4 qualifying rounds and makes the better teams much more represented. With 16 teams picking, many teams that were put in bad situations like the one you described, yet still showed that they had an excellent robot, will be picked. Hopefully. Anyhow that's my 2 cents worth.
: I've got two messages, but i'm putting them together because they are closely related.
: First a little backround:
: I want to recognize the Navy team, ("Das Goat&quot. They got a very bad run of luck. When we (Team #88 TJē) were allied with them on Friday, we popped a fuse during power check. They had to play the match without our robot.
: Then things went downhill from there. Saturday, Navy was allied with team 219, who (for reasons unknown to me, keep in mind there might a good reason) packed up and went home on friday. Then by another unbelieveable run of bad luck, they were allied again with team 219 in a later match.
: Here's the worse part. If your alliance partner is a complete no-show, FIRST rules allow for no replacement of the human player. That means the 3 floppies in the player station, are effectivly out of play.
: That the facts, now here's what I want.
: Change the rule for florida, to allow you to have a human player. I don't really care about not having an alliances robot on the field, but having 3 floppies locked away from you from the begining of the match is very brutal. There are numerous ways of filling that player station, from a second human player from your team, someone picked by FIRST, maybe even one of the FIRST Crew members.
: I think this is one of the situations that FIRST never even thought of, hence they didn't have a rule dealing with it.
: As for the Reason for more seeding rounds, I think you can see why, The Navy team was without an alliance robot 3 times, and without an alliance 2 times. I didn't catch the rest of their matches, but if there were only 4 matches.... well I know you can see where this is leading.
: Thoughts?
: Mike
[IMG] code is Off
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
