Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Unread 30-10-2007, 19:06
Back after 4 years off
FRC #5279
Re: USB - Serial cable
Originally Posted by Tottanka View Post
Any ideas anyone?
Download the CMUCam2 GUI and capture an image with the light in it. Next select the light and check to make sure that the values Y, Cr, and Cb are within the ranges you found when you calibrated the camera.
If the red light does not come on then the camera doesn't see the light, it must either be out of focus, calibrated wrong, or wired wrong.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
USB To Serial Devo1098 Programming 3 30-06-2007 19:51
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
usb to serial cable karinka13 Technical Discussion 4 10-02-2006 17:30
USB-Serial Cable + Terminal Spencer E. Programming 3 22-01-2006 12:16
Serial Cable Andrew Rudolph Technical Discussion 9 15-08-2002 22:09
