Go to Post It's easy to get overwhelmed. Don't get overwhelmed, just keep working at things a little bit at a time. (Oh, and don't forget to have fun!) - DominickC [more]
Unread 31-10-2007, 10:03
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Unknown Device ID(0)
Hi, we're getting this error on the IFI Loader with a laptop connected with a usb-serial adapter. It works fine when connected directly to the camera, hyperterminal and the labview application work fine. When connected to the RC though it gets this error when trying to connect. Any ideas?
Unread 31-10-2007, 10:29
Re: Unknown Devide ID(0)
That generic error simply means the Loader isn't communicating with the device.
It can happen when the wrong COM port is chosen in IFI_Loader, but also when the serial connection is bad.
Check any cable or connection that's different from when you connect to the camera, and double check the IFI_Loader selected COM port and port settings. Just run a quick test through all the COM ports IFI_Loader offers up.
Unread 31-10-2007, 10:57
DavidGitz's Avatar
I think if you pick the wrong COM port it says "Can't Connect" or something like that. But COM1 is selected. When I switch from the camera to the RC board, the only thing that I change is to install the TTL chip.
Unread 31-10-2007, 11:07
Sounds like the only change is your laptop application (IFI_Loader), and you just unplugged the serial cable from the camera and reattached the serial connector to the RC Program port. Concentrate on what changed.
A wrong COM port in IFI_Loader under certain circumstances will also return Unknown Device id (0).
USB-serial adaptors on laptops usually default to COM3 or COM4.
It doesn't hurt to quickly run through the ports in IFI_Loader.
The TTL converter isn't in the communication path, so it won't affect connecting the laptop to the RC.
Unread 31-10-2007, 12:13
DavidGitz's Avatar
Ok I'll check that out Mark, thanks!
Unread 31-10-2007, 13:35
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Unknown Device ID(0)
Click Options>Controller Verification, and post everything the status bar says.
EDIT: I've had a similar issue when I've programmed the EDU or Vex controllers from IFI Loader. Usually if I do a controller verification it solves the problem.
Eric Haskins KC9JVH
Unread 01-11-2007, 13:45
DavidGitz's Avatar
Thanks Mark you were exactly right, I had the wrong COM port. It works great now, thanks!
Unread 03-11-2007, 09:44
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
hi, i'm having the same problem, however, i know the usb-serial adapter is in the right port, i've run controller verification. what else could it be?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 03-11-2007, 21:50
Controller verification does not confirm you are using the correct serial port.
I know it should, but it doesn't.
What could it hurt you to step through each of the COM choices in IFI_Loader and click Download after each one?
We can go on to other possible causes, but we'll need to know you made the most obvious tests first.
Unread 19-01-2008, 10:56
paulcd2000's Avatar
AKA: Paul Dagnelie
hey, me again. never did solve it. Now, i'll be ok, since i have other teammates with laptops. But this still bugs me, so i want to know how it's done.
i ran through every port, nothing runs controller verification or downloads but 3, and 3 only does controller verification. Same thing after i reinstall the driver. COntroller verification gives me:
Version|FRC|FRC|115200
i'd really appreciate it, not just for me, but for other people who have this problem
EDIT: so none of my teammates laptops work either
Any possibility besides trying to replace the cord?
Unread 20-01-2008, 18:03
Next I'd suspect the cable of course, then the USB Adaptor.
Do you have an alternate Adaptor you could test?
Are you able to download from any desktops?
Any nearby teams you could take a field trip to just to see if you can download to their controllers or get them to try your USB Adaptor and cable on their working machines?
Unread 28-01-2008, 20:01
paulcd2000's Avatar
AKA: Paul Dagnelie
alright, so we bought a new adaptor, and that worked for a good while, until tonight, when all three laptops became unable to load code. We're wondering if there could be some kinda problem with the RC? or maybe just WIndows?
Unread 28-01-2008, 20:10
in between teams
AKA: Luke Van Oort
We've ran into this issue on two out of the three laptops we've used for programming (the third has a real serial port); in all cases, the fix was reinstalling the driver. I would give that a shot.
Team 1219: 2009 - Mentor
Unread 28-01-2008, 20:28
paulcd2000's Avatar
AKA: Paul Dagnelie
we did, twice. no dice. we'll try again with the original disk on friday, but until then, i'll guess it won't help. Let's assume it doesn't. is my only recourse to by another new USB-SERIAL cable?
Pneumatic device wrenauld Pneumatics 3 24-01-2007 10:28
FIRST Unknown irishninja General Forum 4 24-04-2006 08:45
Unknown Blinky-light type Errors. Astronouth7303 Programming 10 12-02-2005 12:24
IFI Loader:Unknown Device id (0) Tridelvior Programming 4 12-02-2004 16:57
