Go to Post Search is amazing. Give it a try. It's 10,000 lines of code that gets lonely if it's not played with often. - Brandon Martus [more]
Unread 31-10-2007, 11:07
Re: Unknown Devide ID(0)
Sounds like the only change is your laptop application (IFI_Loader), and you just unplugged the serial cable from the camera and reattached the serial connector to the RC Program port. Concentrate on what changed.
A wrong COM port in IFI_Loader under certain circumstances will also return Unknown Device id (0).
USB-serial adaptors on laptops usually default to COM3 or COM4.
It doesn't hurt to quickly run through the ports in IFI_Loader.
The TTL converter isn't in the communication path, so it won't affect connecting the laptop to the RC.
Pneumatic device wrenauld Pneumatics 3 24-01-2007 10:28
FIRST Unknown irishninja General Forum 4 24-04-2006 08:45
Unknown Blinky-light type Errors. Astronouth7303 Programming 10 12-02-2005 12:24
IFI Loader:Unknown Device id (0) Tridelvior Programming 4 12-02-2004 16:57
