Go to Post Ok, I am geting flustered since I can't perform trigonometric functions with the tools FIRST provides. - jweric [more]
Unread 31-10-2007, 07:25
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Contact Area and its Relation to Friction?
Ok, I've searched around and have found many posts on CD dealing with this question... but no one has given a concrete answer.
As many of you know... a normal force * coefficient of friction = friction force... at least in everybody's text book.
Obviously more contact area increases traction, or else race cars would have little skinny tires, not big fat wide tires. So... where does contact area factor in to friction force? I think it might have something to do with the non-homogeneous nature of tires and carpet or tires and asphalt or whatever the contact situation may be in most real world tire/track/other land propulsion applications... but I don't have an equation to give me friction force with non-homogeneous surfaces in that case.
I'm hoping i don't have to break down and dervie a formula from empirical data, but if thats what has to happen so be it.
Does anyone have a concrete (preferrably mathematical) answer to this vexing (or first-ing ) problem?
Thanks CD'ers/FIRST'ers,
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 31-10-2007, 07:33
Re: Contact Area and its Relation to Friction?
Q,
Andy Baker or Raul Olivera will have a good handle on this question. You may want to PM them or use the email option directly in case they haven't seen this thread.
Unread 31-10-2007, 07:37
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
This isn't exactly a mathematical answer, but a quick search on google gives this link:
http://www.physlink.com/Education/As...TOKEN=72229625
Remember that most physics books deal in an ideal world where most things are point masses and all surfaces are completely uniform and flat.
Consider too that since Force=Pressure*Area, that as area goes up, pressure can go down resulting in tires that can be made of softer materials or in the case of pnuematic tires, thinner walls because they need to contain lower air pressure.
(but I'm a Computer Engineer not a Mechanical one, and could be completely wrong too)
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 31-10-2007, 08:16
At their operating temperature, race car tires are actually sticky, so they get traction related to contact area, regardless of the weight. They're also made of soft and relatively weak rubber, so they need to be wide in order to spread out the force and keep from tearing under acceleration.
Dragster tires are extremely wide because dynamic friction does depend on contact area, and they want to maximize the acceleration even when the tires slip.
Unread 31-10-2007, 08:56
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Q,
In 2003, we TechnoKats did a bunch of friction tests to compare the coefficient of friction between various types and sizes of rubber on the HDPE ramp. We also compared the forces required to push a robot on carpet depending on the type of drive base it had (wheels vs treads).
We found that there is a very, very slight (under 5%) advantage to having a larger surface area on the plastic. This could have been due to a number of things... but each time we pulled on a larger area sample, it took a bit more force to move our object.
We also found this same slight advantage (about 5%) when comparing treads to wheels on carpet. A treaded robot was a bit harder to move.*
In both cases, there is not an ideal flat-to-flat surface interaction. I believe that the mechanical interaction between one surface and the other creates this slight advantage for larger surfaces. It's easy to see between wheels and carpet, and it's at a smaller scale between rubber and HDPE.
* - This test was enough to prove to me that treads on a FIRST robot were NOT worth the effort. We did treads in 99, 01, 02, 03, but not ever since. We were very surprised at the results and did not see the 5% advantage justify the effort to do treads. Even though there is this 5% increase in the friction coefficient, a track system has more efficiency losses (maybe as high as 5% more, to offset the friction advantages) and uses more hardware to make the system weigh more.
I'll contend that a wheeled FRC robot will push with as much force (within 3%) as a tank tread robot, as long as some conditions are met:
1. The robots weigh the same
2. The robots have similar Cg locations
3. The tread material for the wheels and treads are the same
4. There is a PID control system for the wheels (and the treads, to make it fair) so they don't slip
All of these friction comparisons above were between STATIC situations. During a static comparison (when the wheels or treads are not spinning or moving), then the friction is very close. I believe that in FIRST, a wheeled robot with good treads on the wheels will hold it's ground very well until the wheels start spinning and DYNAMIC traction starts to come into play. Possibly the reason why treaded robots push around wheeled robots at times in FIRST is because wheeled robots get into dynamic friction situations by not having a traction limiting program, like PID control.
This is definitely an area where more testing is needed. I am sure that others out there have opinions on this, and I am eager to see what people say.
Andy B.
Unread 31-10-2007, 10:01
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm hoping i don't have to break down and derive a formula from empirical data, but if thats what has to happen so be it.
Friction is weird, so yeah, you probably do have to derive a formula from empirical data.
An example of friction being weird: Most material interfaces have a higher coefficient of static friction, than of dynamic friction. But aluminum to aluminum has a higher coefficient of dynamic friction than static friction.
And when you consider automobile tires, think about what might be happening when the situation in my avatar occurs....
Good luck!
Unread 31-10-2007, 13:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
PID Traction Control -- unless each wheel on a given side is indepedently driven from the transmission, what reliable way exists to tell the difference between wheel speed and robot speed? Being able to tell the difference in traction loss vs. the robot turning seems even more difficult to grasp.
GitHub
Unread 31-10-2007, 16:31
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Another impact of contact area is in turning itself. We all know that the bots turn different on a hard floor like concrete than on the competition carpet.
<speculation>The carpet under the wheel locally acts like a spring. We know that things sitting on carpet sink in some amount (especially obvious when moving furnature) and the the area of carpet engaged affects how far into the carpet the item sinks. Therefore by increasing the size of the wheels contact patch (relative to the other wheels) we can affect the amount the wheel sinks into the carpet. <edit> ...by making the larger carpet patch behave like a stiffer spring</edit></speculation>
How does this impact the friction? By moving changing the normal forces. It won't change the overall pushing capacity of the bot, but it will allow us to change which wheels have the majority of the traction. This is really what we are doing when we drop the center wheel of a 6x6 after all isn't it. So by widening the center wheel we can move the normal forces to the center axle which lessens the normal loads at the corners... reducing skidding forces... making it easier to turn... with less wheel drop (and rock)... without giving up pushing force.
Attached is a crude spreadsheet attempting to explain my point.
p.s. I am working on getting hard data to back-up my point, but until then feel free to roast me.
Mark
Brick walls are for other people. - Randy Pausch
Unread 31-10-2007, 17:21
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
I also don't understand the idea of PID traction control. I've heard of PID velocity control using encoders, and I'm planning to implement that on our robot this year, but I don't understand the idea of PID traction control. How would you do that?
Jesse, there are some ways. One way is to have a passive wheel on an independent axis in the center of your robot, and encode it. It will only move if the robot is moving. You could also use mouse sensors or trackballs to accomplish similar things, I think.
Unread 31-10-2007, 17:35
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
This thread is pretty well covered. However, the math and actually what happens on the FIRST field regarding friction are two different things. Mark I like the spreadsheet some interesting data there nice work. My suggestion regarding this is test,test and test. In addition to that remember the basics for instance you want to be heavy as possible without being overweight especially with a game like 07's. watch your CG and keep it as low as possible and finally keep your tread in keep in good condition at all times. Besides this experiment with different materials and tread widths, design is an on going process. Finally, you don't want to spin your wheels in a pushing match, thats how you get pushed. The easiest way too figure this out is to put the bot pushing against the wall and record the numbers from dashboard when the wheels slip then set them up in programming as limits. Obviously do this while the bot is on a practice field were real carpet or as close to real carpet is present to get the most accurate results. Just a few things my team is doing regarding this issue
my two cents,
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 31-10-2007, 21:33
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
I find this concept very confusing. So it takes more force to continue to move aluminum against aluminum then it does to start moving it I read this and I thought to myself.... well that just can't be right, so I looked elsewhere to verify it, and go figure it's true. I just don't see how that works.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 31-10-2007, 22:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
PID traction control is pretty simple, just not anything that's typically done in FIRST. The whole point is to keep your wheels from slipping. Wheels slip when applied force exceeds the static friction force. Applied force is proportional to applied torque which is (mostly) proportional to motor torque which is proportional to motor current. So your goal would be to PID control the current being supplied to (or sourced from) the motors. Current-mode motor drivers and amplifiers are awesome for this, but we don't have any, sooo the idea would be to use a solid state current sensor on your motor leads, and PID control this.
Now, I'm not sure our available loop rates are really adequate for good stable control of this current, but you could certainly easily implement a simple controller to back-off on commanded PWM signals to keep the current in an acceptable bound that you know won't slip.
The above means I'm slightly skeptical about programming hard limits into your code based on what PWM values caused slipping at a stand still against a wall. The PWM values control (to a 1st order approximation) the voltage that you're applying to the motor, not the current. As a motor spins, it creates its own source of voltage (back EMF) proportional to the motor speed that cancels most of this out, with the left over voltage differential driving the current flow and thus creating torque. What this boils down to is that, if your robot is moving forward while you're commanding a constant voltage, you're theoretically applying less torque than you could get away with. Annoying, but not really a problem. However, if you're applying your constant voltage and still getting pushed backwards without slipping, this actually increases the torque you're putting out. Which means that if someone pushes you back fast enough (and it doesn't have to be a lot if you're cutting things close) you'll suddenly put out too much torque, spin your wheels, and very rapidly lose the pushing match. Plus, you'd be pointlessly limiting your top speed when you're not pushing someone, because you've simply put in a limit to how much voltage you'll put out and, thus, what your top speed is. Now, there are ways to compensate for this using velocity feedback and such, but they're not going to be as accurate and reliable as a current sensor feedback.
Unread 01-11-2007, 13:20
JesseK's Avatar
FRC #1885 (ILITE)
I apologize for continuing off on a tangent, but I feel we're on a roll with the tangent and it's pertinent to the original topic to an extent. The biggest advantage I see for traction control is the ability to climb rough terrain (ramps) without too much driver input.
We too use the encoders for PID velocity control in order to keep the robot driving straight at high velocity.
Hmm, after a bit more thinking the mouse sensors seem easy enough to do if you have 1 mouse sensor on each side -- even though the PID control, for perfection and theory, would slightly change during a turn (higher I value) than in a straight (higher P value). I'll have to bring this up to the drive train design team tonight to see if we can focus a bit of time experimenting with it.
This might be a good start for general traction control as I know exactly what you're talking about. We definitely need some data before we can come up with anything concrete for limiting values however, and be able to test many scenarios to make sure it dynamically understands turns vs straights. We'll also have to review the rules on custom circuits since this sensor would be inlined with the motor leads. Bah, such a great idea so little time!
GitHub
Unread 01-11-2007, 20:58
Similar sensors were legal and included in the Kit a few years ago. In fact, R62 and R63 from last year make it clear that these are legal. And yes, making the control adapt properly to the dynamic nature of the FIRST field would be challenging. I think true traction control would be decidedly difficult, and would basically end up monitor wheel velocity and motor load and maybe a few other factors to decide if the wheels actually are slipping.
Unread 01-11-2007, 21:54
Joachim Joachim is offline
Joachim has a spectacular aura aboutJoachim has a spectacular aura aboutJoachim has a spectacular aura about
Grippy non-linear materials like natural rubber, when on relatively smooth surfaces, can have a higher effective coefficient of friction at lower pressures--so for a fixed robot weight, larger contact patches can give higher friction becuase the rubber of the contact patch is under less pressure.
For an experiment showing the non-linear coefficient of friction of rubber (higher coefficient with lower load on the interface) see http://www.tuftl.tufts.edu/files/asu..._Testing.2.doc particularly graph 1 and graph 3. See also http://www.robotbooks.com/robot-materials.htm toward the bottom of the page, where you find the statement:
"The confusion here comes from the fact that rubber has a very unusual property. The more lightly it is loaded, the higher its apparent coefficient of friction."
Of course carpet can change everything, so you need to experiment for yourself.
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Technology and its future role in highschools... Ashley Christine General Forum 19 13-04-2005 08:30
Team 599: Its done and it works. Jojo2k1 Robot Showcase 12 17-03-2005 01:51
Friction as a function of area rbayer General Forum 28 31-01-2003 07:28
