Go to Post Perfection of a system comes not when you can add nothing more but instead when you can remove nothing. - Andrew Schreiber [more]
View Poll Results: How interested are you?
I'll probably help develop it 13 25.49%
I'll probably beta test 11 21.57%
I'll probably use it 16 31.37%
No interest at all 11 21.57%
Voters: 51. You may not vote on this poll
Unread 31-10-2007, 23:17
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Re: Eclipse Development
Originally Posted by cooker52 View Post
It says that I am up to date on the latest download.
I got curious and looked in my hard drive. What I found was that right in the C Drive was the file Eclipse keeps referring to what I have. Moving into my program files, I found the Java folder. Here's what I found. Now what? Any ideas?
Just delete everything in your Java folder except for the JDK 6.01_03 and JRE 6.01_03. Java doesn't remove old versions when it updates, since some Java apps require certain versions of the JVM. The good news is that clearing out all of those old ones will probably free up a gigabyte or more of storage space ^_^
Eclipse Plugin Maintaineer? duane Programming 21 31-10-2006 22:34
Eclipse Visual Editor Mike Programming 9 27-09-2006 14:05
using eclipse dasRatsel Programming 82 02-01-2006 13:20
Eclipse code formatter Astronouth7303 Programming 0 24-12-2005 17:39
Eclipse with CDT Nis Programming 2 15-06-2005 09:31
