Go to Post This season, I learned that I will need a whip next year for keeping the electronics and pneumatics groups on schedule. - Yan Wang [more]
Go Back   Chief Delphi > Competition > Team Organization > Fundraising
Unread 01-11-2007, 15:09
Onward through the fog.
LAN Party Questions
Has anyone had experience with a LAN party as a fundraiser?
Can you tell me about basic needs, please? If you want to suggest games, cool - but I'm interested in set-up/power needs.
If we have a set-up for 20, what do I need to provide?
Tell me about plugs, etc.
I don't want to blow up my donated space. Seriously.
Thank you in advance.
Jane
~ Helen Keller
(1880-1968)
Unread 01-11-2007, 15:30
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: LAN Party Questions
Normally the participants would bring their own computers. For every person you would need at least 2 plug in spots for power, one for monitor and one for computer. Most LAN competitions impose rules on the size of monitor you can bring to save space, also most require that you use headphones instead of speakers. You will need some kind of network that everyone can access. Depending on what game you would likely need a computer to run a dedicated server for the game.
Popular LAN Party games are:
Counter Strike Source
Battlefield 2
Day of Defeat Source
Google brought up these sites they seem like they are probably of use:
http://onepc.net/index.php?view=docs&doc_id=75
http://www.lanparty.com/
Unread 01-11-2007, 15:32
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: LAN Party Questions
Power:
Depending on the type of computer(Desktop or Laptop), and the type of monitor(CRT or LCD), I'd have no more than 5 desktops with no larger than 17" CRT monitors on a single circuit. Laptops can go as many as 10 per circuit.
You will need to provide power to where each computer will be located, I recommend using a heavy duty extension cord from the wall outlet to a good surge strip located where computers will be located, possible have the power in the center of a ring of tables. If you plan on having a game server dedicated to running one particular game, use a battery backup in place of the surge strip, that way if the extension gets unplugged the game won't immediatly crash.
Connectivity:
Network switches are needed to connect all the cumputers together to the ethernet(RJ45) port in each computer. You can use wireless access pionts to reduce the amount of wiring needed, but each computer that uses it will require a wireless network card.
Games:
Halo, Counter Strike, Age of Empires II, Starcraft and Broodwars expansion, Warcraft III Frozen Throne.
Other:
Set what times the LAN party will go till, what the admission costs are if any, what food will be there. As for the fundraising part, you can charge admission, have a donation jug, raffle off some piece of computer equipment, etc.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 01-11-2007, 15:35
Are you doing this at a house or a school or a ... ? If it is not in a house, you are fine.
I've been to at least one LAN party that browned out the host's house, so you are right to worry. However, 20 isn't that bad, so I wouldn't worry too much.
Do not allow anyone to bring speakers, headphones only. This is mostly just a courtesy thing, but speakers can draw unnecessary current.
Laptops are handy because they are easy to set up / take down, and they don't draw a whole lot of juice. My laptop's power supply is 60 W, my desktops power supply is 500W. However, gamers largely prefer desktops for good reason.
LCDs consume about one third as much energy as CRTs. Your mileage may vary. I've read that it is 50W vs 150W, but again, your mileage may vary.
After those power saving tips, it isn't too hard to eyeball where your power needs will be. Each circuit should give you about 20 Amps / 2400W (double check me on that please). Thats enough for 40 laptops or 5 desktops (safely). You can probably put 10 desktops on that circuit before it pops, unless they do something silly like all play a game at the same time.
Back in 2002, we had all had clunky desktops with CRTs. We popped breakers on two circuits in the house and borrowed power from the neighbors during a 25 person LAN.
Good luck, and have fun.
Unread 01-11-2007, 15:42
No, not in a house - in a professional building probably about 9 years old.
What about *cough/choke* 40 participants?
The original plan was for about 40 - I'm going conservative with 20 but the advice for 40 would be welcomed as well.
Thanks for all of your help, everyone. Maybe we can make a white paper out of this. It would be cool.
The important thing is for my hair not to fall or brown out.
Jane
~ Helen Keller
(1880-1968)
Unread 01-11-2007, 15:59
Scott L.'s Avatar
Lightbulb Re: LAN Party Questions
Is this a school inviroment, lan party attendees usually need to grab the latest update or patch, and most school networks block these sites. If this is the case find out what games will be played and download the patches etc into a common folder shared over the network and let everyone know where they're located.
40 attendees is no problem, just use the advice given. so if 20 people required 2 circuits, than 40 would require 4 circuits. Also don't forget the power requirements of the network equipment like routers, switches, servers, etc.
also make sure you have access to the breaker box in case a circuit should trip. Static IPs are good if no router is used, people signin and get the ip next to were they sign. Dynamic IPs make it easier sometimes, IP is assigned by a DHCP server/router.
I haev experience running a LAN party so if you need help send me a message.
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
about the network make sure to have enough "patch cables" (rj45 category 5 ethernet cables) to connect all the computers to the swithc / hub and make sure they will be long enough. it would be good to get at least a 100 mbs switch 1 gigabit (aka 10/100/1000 baseT) would be better also switches are usually faster than hubs as they allow more than one person to have a "conversation" with someone else at the same time.
hope that helps a bit
...forest
Unread 01-11-2007, 17:43
BorisTheBlade's Avatar
BorisTheBlade BorisTheBlade is offline
lead programmer 2004
AKA: Dane
FRC #1351 (TKO)
BorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura about
Send a message via AIM to BorisTheBlade
here is my advice and just to let you know I have helped put on 50 person lans all the way to 150 and I have been to 500 person lans. The most important thing about running LANS is POWER you can damage the building or peoples computers if you dont do it right.
here is what you need:
Power:
you need enough power to provide for 2 plugs per person 1 for monitor and 1 for computer. most lans do not allow anything else like external speakers and things like that that take extra power. Generally you need about 40amps per circuit with one circuit providing power for 4 computers. most LANS require no more than 500-600 watt power supplies for the computer and no CRTs above 17" inches or LCDS above 24" if all of that is met you should be good on power.
network:
generally you have a switch or too depending on the number of people involved. Good switches usually come in 24 or 48 ports. Most of the time you run snakes to central locations basically they are just a bundles of Ethernet cables with female jacks on end and male on the other. you plug the male ends into the switch(s) and leave the other ends for players to plug there own cables into. just make sure your cable runs don't exceed 100m as cat5e ethernet is only rated to go that far. be sure to take into account the players cable as well general rule of thumb 15 feet minimum for their cable. as for swtich speed 10/100 is ok but 10/100/1000 is best but more expensive for a switch.
all thats left is people to show up with their computer and plug in.
hope this helps if you have any questions feel free to send me a PM
Team 1351 TKO Robotics (click for our website)
2007 sacramento regional Johnson & Johnson Sportsmanship Award winners
2007 CAL Games Finalists
Unread 01-11-2007, 18:04
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
We were thinking of doing a similar one at our school for fundraising. (We are after all a ROBOTICS team) the neat thing is that our school is three years old, so new comps that are pretty decent. Our school is also entirely networked (if thats how you say it?) and we play games on them anyways.
I was also thinking of doing one at my house with 15 or so computers on 4 different circuits, soo would that work at my house? I think all 4 are 20 amps, maybe one of them is 15 amps. Also is it ok if I am running other things in my house like TV, Refrigerator....OH and lights?
Games: I hear Quake is a popular LAN game even though its outdated. I would go with RTS, Warcraft III, Age of Empires. Counter Strike definetely. Wolfenstein, I hear is a good game...AND SOLDAT!!!!!!
Unread 01-11-2007, 18:09
in between teams
AKA: Luke Van Oort
I don't think this has been specifically mentioned; make sure you have a switch/router, not a hub. The difference is a touch technical, but computers communicating through a hub is like trying to get a message across a room when everybody (including you) is communicating in Morse code--with airhorns. Communicating through a switch is like having everybody make quiet phonecalls to one another. Naturally, this makes a huge difference in the game's performance.
Team 1219: 2009 - Mentor
Unread 01-11-2007, 18:35
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Never been to one before, but the most popular multiplayer LAN games to date are:
Quake
Warcraft III
Counter-Strike
Call of Duty 2
Battlefield 2
Halo CE (and I guess Halo 2 for Vista now)
Also, I strongly agree with the headphone requirements. I play at a game center where they used to provide headphones until people started abusing them. Now they switched to speakers, and it's a lot of distracting sound with only 16 PCs. I can't imagine that kind of noise more than doubled. Plus, I know I like to use a microphone anyway, so I usually prefer headsets.
Nice idea, though! I might see if we can muster up something like that.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 01-11-2007, 19:29
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Make sure the network is set up properly, and there's enough plugs. You can pull up to 1800w from each outlet on a plug (120v / 60a), so you can get 2-4 computers on a single plug (but keep it down to a minimum if at all possible).
To give you an idea:
Tech High has 80-120+ person LAN parties every few months and there hasn't been a power issue in three years (and even then it wasn't that bad, one circuit broke and shut off my computer and three others, but that was it).
Speakers are fine, but if you DO allow people to bring them (which you shouldn't in this case), make sure that the attendees collaborate and share speaker time OR play music everybody likes.
Hope this helps.
-Otaku
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 01-11-2007, 20:40
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
So i know that this is more about computer LAN Parties and such. But, what about have something such as a Xbox 360 LAN Party. Many people on our team have 360 already and the idea just came into my head.
Sorry if this is a little hijacking, and semi off topic.
Could you do it? Have you done it
More of the same questions what would you need to make it happen hypothetically?
Again sorry,
just had to put the idea out there.
-Sean
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
Unread 01-11-2007, 20:48
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Again sorry,
-Sean
Well with my experience with X-box lan parties, you all just need to be in the same router. With the X-box only 16 people could play at once, so 4 per x-box and 4 xboxes... i dont know what the physical limitations on players on a LAN game are with a 360, but it should work if you just all plug into the same router.
Unread 01-11-2007, 23:42
synth3tk's Avatar
AKA: David Thomas
It has been done before, and like Sir Charles said, you just have to plug them into the same router. The only thing you have to watch is the game's multiplayer limitations.
Richmond FIRST LAN Party Cuog Chit-Chat 3 28-02-2006 18:43
ROCHESTER: Arena 51 LAN Party! Ashley Christine General Forum 28 15-01-2006 22:43
Fundraising Idea - Lan Party Yan Wang Fundraising 23 25-03-2005 23:10
CD Lan Party MattK Chit-Chat 9 12-12-2002 17:57
LAN party, anyone? FotoPlasma Chit-Chat 31 14-02-2002 12:59
