| When you're around my motors redline. |
#16
Re: What Laptops do you recommend?
You got some pretty nice recommendations here from CD's own "elves"!
I'd agree with getting a Dell or MacBook, especially the Vostros/Inspiron.Also have to ditto the avoidance of HP AT ALL COST!!! Bad quality and support, and not a very good deal for your money. |
#17
#18
Using my brilliant knowledge of vBulliten's original URL specifications combined with mad researching "skilz", super sleuth abilities, and all-powerful computer knowhow, I have undoubtedly positively corrected your thread link in beautiful Technicolour!!!
http://www.chiefdelphi.com/forums/sh...ad.php?t=50086 |
#19
If you've read many of my posts, you'll know I think tablet PCs are great. They're more expensive than a noraml laptop, but once you've used one, you'll never go back.
This is the setup my brother has: Gateway C-140X 1.66 Core2 duo(an additional $5) 1gb ram, but replaced by a pair of these 1gb sticks. That was a ten minute job that saved $100. 80gb hdd 12 cell battery, can litterally get 8 hours on battery power!!! He also paid for $30 for a fingerprint reader, but I didn't include that. Total cost $1050 including shipping, but you can save some more if you watch for deals. I know this isn't the cheapest computer, but tablet PCs are great! EDIT: If you need more storage get one of these. I have a pair of those that stay in my computer case all of the time.(they're 75% full) ![]() Last edited by EHaskins : 31-10-2007 at 13:59. Reason: typo |
#20
What would be the difference between 1.4 ghz, 1.66 ghz, and 1.83 ghz core two duo processors when running inventor or gaming?
I will still have 2 gb ram and 128 mb video card. as a poor sophomore in high school without money the processors are pretty expensive ![]() thanks, vivek. p.s. I will probably choose 1.66 but I was just wondering what you guys think? Last edited by vivek16 : 01-11-2007 at 17:18. |
#21
The decision of choosing between those processor speeds are akin to the question of which car you buy. Sorta. The faster it is, the better things run. Actually, that car bit was an outright lie. Just a side note, if you're playing higher-end games such as BF2, CoD2, ET:QW, and so on, then 1.66 may not deliver that well. I've got a dual core 1.60 with 2 GB of RAM, and it's barely running my games on Low/Medium-Low. Then again, it is a laptop with sucky integrated graphics, but 1.6 GHz dual core on a desktop would still let you "just get by".
Although I do understand your position, since I'm trying to build a gaming machine on part time wages, try to find some good deals and treat yourself to at least the 1.83. You'll be glad you did. http://www.tigerdirect.com http://www.newegg.com [Recommended] http://www.ebay.com [Not-So-Recommended, But Still An Option] Last but not least, the RAM is more than sufficient for what you'll be doing, and the video card sounds like it's good. Kudos in those departments. BTW, what's the video card model? If you need assistance, I might just help you out with buying your processor, really got nothing else but robotics to spend my money on! Last edited by synth3tk : 01-11-2007 at 18:56. |
#22
PROCESSOR Intel® Core™ 2 Duo T7100 (1.8GHz, 2MB L2 Cache, 800MHz FSB) OPERATING SYSTEM Genuine Windows Vista® Home Basic edit LCD PANEL 15.4 inch Wide Screen XGA LCD Display with TrueLife™ edit MEMORY 1GB Shared Dual Channel DDR2 SDRAM at 667MHz, 2 DIMM edit HARD DRIVE 160G 5400RPM SATA Hard Drive edit OPTICAL DRIVE 8X CD/DVD Burner w/ double-layer DVD+R write capability VIDEO CARD 128MB NVIDIA® GeForce™ 8400M GS edit MEDIA DIRECT Dell Exclusive MediaDirect™ Instant Play Software App WI-FI WIRELESS CARD Dell Wireless 1390 802.11g Wi-Fi Mini Card edit It has all the specs I want besides the ram which I will upgrade seperately. it works out to less than 800 dollars total with 1.83 ghz c2d processor, 2gb RAM, and that video card and specs listed up there. here is the link to the website: http://www.dell.com/content/products/productdetails.aspx/vostronb_1500?c=us&cs=04&l=en&s=bsd&~tab=bundlesta b I chose the Enhanced graphics Performance option and customized with basic vista. I have xp pro that I will install onto it. Should I get the Intel wireless card or keep the dell one? thanks, vivek Last edited by vivek16 : 01-11-2007 at 21:33. |
#23
Oh, ok. I don't know why I thought you were actually upgrading the system. Yeah, that's a steal for the price.
As for the wireless card, I see no reason to change it unless your connectivity needs are different. From what I read on Dell there's two Intel cards. One adds 802.11a support (pffft) and the other adds draft-N. The key word in the latter card is "draft". I'd avoid going with this one especially since it's built into a laptop. I say this because the specification for N isn't set in stone yet, as it were. Bottom line, you may end up paying for something that won't be very compatible with the final routers at all. Not that I'm implying it won't for sure, but the possibility is there. And the one with A? Please, what consumer really uses it? Just save money and go with the Dell. |
#24
#26
Yes, true. But still, unless he really truly needs it, it's just a waste of money anyway.
#27
what exactly would I use N for? I probably wont
#28
Well right now, not much, but as it surpasses G by a mile you might as well get it. G right now is the standard, but I personally see N coming up to become the standard in a year or so.
#29
are they router dependant? so would A, N, and G be able to pick up the same router signal?
#30
It kinda goes both ways. The card in your computer has it's limitations to what it can receive, and the router has it's limitations to what it can transmit. Most routers today broadcast in more than one mode (b and g for the most part). This is done so then if you have a B only card in your laptop, or a G only, then you will be able to pick the signal up still. Also this makes routers and wireless cards more universal.
| Championship 2007 - Atlanta - What Went Well or What You Liked | dangerousdave | Championship Event | 38 | 22-04-2007 12:07 |
| what what would you like to see in a team website? | fimmel | Website Design/Showcase | 24 | 08-11-2006 08:32 |
| What do you wish you had known when starting college? | Katy | College & University Education | 62 | 23-04-2006 19:52 |
| What do you call a sale at your house of items that you have? | Elgin Clock | Chit-Chat | 52 | 07-06-2005 17:44 |
| Speaking of T-Shirts... What size do you want if you were to trade? | Elgin Clock | General Forum | 0 | 08-01-2004 23:45 |
