Go to Post "Its never too late to be inspired" - Alex Golec [more]
Unread 02-11-2007, 23:16
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
pic: Planetary Transmition
Unread 02-11-2007, 23:19
Aren_Hill's Avatar
Build Nifty Things
Re: pic: Planetary Transmition
are you custom making the planetary reduction or is it a COTS item. and i assume this is for a drivetrain handling 2 small cims by the looks of it?
is there anyway to reduce the gearing between the cims and the planetary to lighten it up?
A guy who likes robots.
Unread 03-11-2007, 02:38
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
1) Is this set up to work with an AM Planetary Gearbox or some other product?
2) Is that a pneumatic cylinder on the bottom for a 2-speed shifter?
3) What is the total gear reduction (or should I say reductions)?
4) Can your planetary gearbox handle the torque of 2 CIMs with the additional reduction?
A very nice, simple design...if it is a 2-speed transmission, it would be very economical as well.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 03-11-2007, 03:17
Fidgetting
1) The planetary shown is the banebots 56mm. However it does not use the week link of the carrier plates, those would need to be replaced and seriously beefed up to make this work.
2) Yes it is a two speed.
3) The reductions are:
High: 3.57:1
Low: 117.86:1
4) I don't know for sure. However planetary gearboxes in general can handle more torque than a spur gear since they have a larger number of teeth contacting. In addition given those reductions two CIM's is a little overkill on the output torque.
Basically i think it could be made to work but I would want to do A LOT of testing on a transmition before actually using one. Mostly its just a concept to be expanded upon.
Unread 03-11-2007, 10:31
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
High: 3.57:1
Low: 117.86:1
is that right? thats one heckuva reduction, if so...
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 03-11-2007, 11:51
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I seriously doubt that a banebots transmission could survive very long with that large of a reduction in front of it and two small CIMs. Maybe you should look into using one of these.
Unread 03-11-2007, 12:47
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
In my day job, I've used Harmonic Drive components (linked above) to construct durable test equipment, intended for many years of service. Their products are very good, and not cheap. Comparing them with competitive robotics parts from suppliers like BaneBots is not simply mixing apples & oranges, it's mixing cannonballs & oranges.
I do agree that the BaneBots gearbox will not survive long in this configuration, at the loads that a CIM motor can drive.
Richard Wallace
since 2003
Unread 03-11-2007, 13:46
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Alex,
Can you post a section view of the inside of the planetary so we can have a better look at how you're planning to modify those transmissions to achieve what seems to be coaxial shifting? Most planetary gearboxes used in shifting transmissions on FIRST robots work my sliding the ring gear between stages, but that'd be difficult to accomplish using a coaxial shifting mechanism.
Also, if you're actually getting a ~117:1 reduction in low gear and ~3.5:1 in high-- It's too early for me to do that math -- consider how useful such a large change really will be. What sort of mechanism might require a ~33.5:1 change in ratio in normal operation?
--Madison--
...down at the Ozdust!
Unread 03-11-2007, 16:42
Fidgetting
Thank you very much for all the comments. The reason that I'm using the banebots is because it comes with many of the necessary gears. I'm developing the concept because it is very easy to change the change in reduction by changing the size of the second planetary sun gear. At the moment with a 22 tooth second gear the ratio changes from 1:30 to 1.1:1. If instead I used the gears from the second stage of the banebots (sun being 30 teeth), the reductions would be 2.25:1 and 1:9 which is a much smaller difference in reduction.
Basically this can have a large number on different combinations of reductions without a change in the form factor. Also if anybody wants to check me on those reductions (would definitely be wise) I think that it would actually work better to have the larger gear on the first stage of the planetary. At the moment I believe the directions of the output would depend on the gear your in. So when you changed gears the robot would change direction...
Thanks again for all the coments
pic: Planetary wheel (cutaway) FourPenguins Extra Discussion 6 01-01-2007 14:56
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
pic: Planetary Wheel - Exploded View 4 Matt Krass Extra Discussion 5 23-06-2005 23:56
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
pic: Drill transmition CD47-Bot Extra Discussion 19 28-10-2003 09:23
