Re: Computer good practices
- When using office 2007, set your default save type as the 1997-2003 compatible versions since at many locations the 2007 viewer does not correctly install. Only save in the .doc/pptX file type IF you are using something that is not downwards compatible. This will help you a lot.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
