Go to Post We need to all remember we are no better than our fellow man, no matter what job we all hold, what socio-economic status that's involved, or anything. Plain and simple, we're all fellow travelers on this pale blue dot called Earth. - trobots.com [more]
Unread 06-11-2007, 03:01
vlad vlad is offline
vlad is an unknown quantity at this point
Help on programming.
Hi guys, I'm currently a project student assigned to work out on a VEX program. My school usually holds competition every year for the juniors and they wish to improve the competition. I've worked out a default code on my own and now im assigned to modify it in such a way that when the timer starts, i could use my own transmitter to send out a Radio Frequency so that the Robots built by the students could than move and when the time is up, my transmitter would automatically send another signal out to stop all the robots. Any idea what codes could i add to make it happen?
Unread 06-11-2007, 07:30
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Help on programming.
you could hook extra recievers into everyones port 2 and all have the same crystal as yours
then they can run a function whenever a button is pressed from port 2 (your controller) use the 'rx input' command to read the button values
or i think you would be able to use this:
http://www.vexlabs.com/vex-competitions.shtml
The Vex Field Controller Kit
Unread 06-11-2007, 20:53
alright. i'll try. thanks alot.
Unread 07-11-2007, 08:50
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
In easyC you could use a competition template. Once the transmitter is turned on the timer will start.
Unread 07-11-2007, 09:03
Billfred's Avatar
Billfred Billfred is offline
If all you want is start-stop, IFI's put out the way to do it (PDF link) with hardware. Hack up a few handset cables, connect them to the tether ports of the radios, and you're rolling.
Unread 07-11-2007, 09:46
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Billfred's solution seems really simple. I like that one the best.
The Vex Field Controller Kit would probably be optimal, because its prebuilt, but I don't see any reason why building one yourself should be a problem.
If you wanted to go wireless, basicxman's solution is good. The only issue that I forsee with this is that everyone needs that bit of code in their program to compete. Furthermore, if their program malfunctions (gets stuck somewhere it shouldnt be), then maybe it won't shut off on time.
My 2 cents.
Jacob
Unread 08-11-2007, 20:26
thanks for the comments. having some problems trying to program it now. help any1?
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
programming help... Shlomi32 Programming 1 08-12-2005 12:28
Programming Help TravisE Programming 1 01-02-2005 19:00
help programming aZnXsa1Nt Robotics Education and Curriculum 5 17-12-2002 15:00
