Go to Post Hold on to your shirts kids, here comes some physics... - JesseK [more]
Unread 07-11-2007, 15:43
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: Code Flashing Issues
MP-LAB? Assuming yes...
Make sure MP-LAB is working the correct subdirectory.
(Easy way, Project -> Close: see what subdirectory it says it's in.)
Make sure IFI Loader is getting from the correct subdirectory.
If you put everything in a new subdirectory to make a new project, the MP-LAB workspace may still be pointing to the old subdirectory.
Sometimes if things aren't working right, the best bet is to copy all the files to a new subdirectory and use project wizard to create a new project. There is a time limit sometimes of how many different things you could try to fix it versus just recreate it.
After Preview: I suppose JamesBrown could be right, that the code isn't reaching the printf, but ...
Originally Posted by bluenp
When it was running, in the terminal I noticed that the change I made in the printf statement had not been made.
I just figured the old printf was printing, so, yes, if there were changes in code around the printf, it could be code issues. Or it may be MP-LAB looking at the wrong locations. (Hey! That sounds like a song!)
Roger.
______________________
Any man whose errors take ten years to correct is quite a man.
J. Robert Oppenheimer
Unread 07-11-2007, 22:14
bluenp bluenp is offline
None #1817
bluenp is an unknown quantity at this point
Yes, I am using MP LAB.
I had previously moved everything into a new folder (and deleted all of the old hex files as to make sure that I was indeed flashing the most current). The thing that makes me believe that it's not flashing correct is that the printf statement occurs and it outputs
offset1: offset2:
and when I was editing the code i made a typo to where it was "offsetf" instead of offset2, however when outputting on the terminal it still says offset2.
Unread 07-11-2007, 23:43
I had previously moved everything into a new folder...
Make doubly sure that you're editing the right file. The editor can keep a connection to the file in the old folder until you close everything and open it again from the project window.
Issues with encoder code jgannon Programming 7 26-03-2006 15:12
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Flashing Battery Light Max Brin Technical Discussion 3 12-01-2006 11:46
Flashing Red Robot Feedback Lights zarf Programming 2 12-02-2005 16:01
flashing LEDs jacob_dilles Electrical 1 22-02-2004 21:52
