Go to Post It's not easy dealing with the reality that others aren't as passionate as we are and that the process may be slower than we want it to be - but it gives me plenty of time to think and prepare. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 07-11-2007, 20:43
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Re: "Essential Tools"
Originally Posted by lukevanoort View Post
A soldering iron, wire crimpers and strippers are very important to have for electrical work (not to mention their important uses for the juvenile humor that comes out after midnight). Although not necessary, a miter saw comes in very handy as does a drill press. A big bolt cutter and a deburring tool can be very useful too. A pop rivet gun and rivets can come in quite handy too. A Dremel can also come in handy, but most of its functions have already been covered by other tools mentioned in this thread. Oh, and get some hole saw bits, you'll need them for swiss cheesing the robot the day prior to ship .
I'd definitely get both. Even if you don't intend to use metric, FIRST may supply something that uses metric.
As for raw materials, you cannot go wrong with a bit of 1"x1" 1/8" wall thickness square 6061 aluminum tube, some 10AWG copper wire, white lithium grease, and various nuts and bolts. I'd be wary of stocking up on materials though--you never know what may become against the rules next year. (I'd say the chance of FIRST banning aluminum tubes, wire, grease, or bolts is pretty small though)
would a soldering iron be absolutely necessary? can u give me an example of a time when u've used a soldering iron when building the robot
would u crimp or solder when attaching wires to a vector
thanks
Unread 07-11-2007, 20:50
thanks
Usually those wires are crimped to connectors, which attach to the Victor. However, there are times when soldering is necessary, such as when working on sensors that don't have their own PWM cable. You need to attach the cable somehow, and I don't think there are any crimps that small.
Also, see what team members have available for team use for a season. This can cut down on immediate cost for tools, allowing you to steadily build up your stock as funds become available.
Unread 07-11-2007, 20:52
in between teams
AKA: Luke Van Oort
thanks
No, it is not absolutely necessary unless you have sensors; generally, a sensor will only have lugs or eyelets to solder a wire to. For Victors, I would recommend crimping; with the size of some of those connectors/wires your average soldering iron may have trouble heating it up causing a cold solder joint -> very bad. One of our team members actually has a 200W soldering iron, but we still don't solder Victor wires, crimps are much quicker and (assuming they are done well) are equivalently reliable.
Team 1219: 2009 - Mentor
Unread 07-11-2007, 20:55
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
These are the tools that I always carry in my pockets; at school, in competition. They never leave me and no one else can use them (unless I am watching):
-Regular pliers (non slip-joint) with wire clippers and heavy wire cutting notches on the side.
-6 inch long crescent wrench.
-6-in-1 double ended screwdriver
-10 foot metal tape measure
-Folding Allen key set, inches.
The pliers are also used as a hammer and clamp, the screwdriver without bits is also a 5/16" and 1/4" nutdriver, the Allen key set is a set of pin punches. MAny other uses as well.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 07-11-2007, 20:57
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
thanks
A Soldering Iron is pretty much an essential. From shrinking heat-shrink tubing to permanently fixing on connectors in high stress areas to etching your team number into a plastic toolbox (jp), it is really a very useful tool.
You can pick up a soldering iron for as little as 5 bucks (I've gotten them for a dollar or free from school events (IEEE)), and it can make the last minute save for many things.
Jacob
Unread 07-11-2007, 21:19
DonRotolo's Avatar
Back to humble
FRC #0832
For the electrical world:
Solderless terminal crimping pliers - but spend the extra money to buy a ratcheting crimper (about $40), that way every crimp will be perfect.
Cutting pliers (able to cut up to #6 wire, which is about the thickness of a pencil) aka 'diagonal pliers'
Good needle-nose pliers
Good stripping tool. Ideally the "automatic" strippers, which have a spring-loaded system to grip and cut the insulation, not the cheap kind that looks like pliers, nor the 'self-adjusting' kind.
Cheap soldering iron plus solder - $10 at Radio Shack, 25 watts. And please, always wash your hands with soap and water after touching solder!
For the rest:
Safety Goggles - at least one pair for every person. Get the good ones, like the $6 ones at Harbor Freight that have the cord to hold them around your neck. CHEAP goggles are AWFUL to wear and use, and nobody will WANT to use them. Decent goggles are not even noticed, fit over glasses, and you can forget that you have them on - everyone will be willing to use these.
Hearing protection - even cheap foam ear plugs. Don't damage your hearing just yet, wait for college at least... A few double-cord dust masks (the kind with 2 rubber bands, not just one) for every time anyone is making dust. Believe me, if you think tobacco is bad for your lungs, try lexan. Several pairs of cotton work gloves.
Plus hacksaws (and blades), files (flat, round, half-round), drill bits (up to 1/2", plus a few uni-bits), an electric drill, tape measures & rulers, sharpie markers, a center punch, a scratch awl, masking tape, wrenches (as mentioned previously), a ball-peen hammer, a rubber or plastic mallet, a bench vice (as large as you can afford), ratchet or C-clamps in several sizes, a chain breaker for #35 chain, a razor knife, a hot-melt glue gun and glue sticks, screwdrivers in seveal sizes (flat, philips), decent protractor...
That's a good partial list.
Note that there is NO Duct Tape on the list, there's a reason for that.
Don
Unread 07-11-2007, 21:29
in between teams
AKA: Luke Van Oort
Darn! I can't believe I forgot that, most of my team thinks I'd build the entire robot out of hot glue if I could! On a similar note, you should probably get some Loctite for vibration proofing bolted connections, and epoxy (clay and liquid kind) for quick fixes at competition or just general adhering needs.
Unread 07-11-2007, 21:34
AKA: Jacob Komar
Originally Posted by Rapt0r9 View Post
We stopped bring metric with us years ago. All the hardware we use is SAE. If you are going to buy just one set, make sure you buy the hardware to go with it. e.g. Don't buy an SAE key set then and metric hex head bolts.
I don't believe there is anything in the KOP, at least from last year, that was metric, so SAE should be a safe choice.
Beware! Banebots stuff is all metric!
Just a little FYI. The english will fit, but strip it.
Jacob
Unread 07-11-2007, 21:40
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
I am surprised nobody has mentioned this yet but the single most useful tool to have during the robotics season is a Leatherman (or an equivalent multi-tool from another company). I suggest that at least a few of your members carry multi-tools with them at all times because, even though they are not the most effective tools for the individual components they have, the ability to carry all of those items with you is priceless.
If students possessing knives on school property is an issue for you like it is with us i suggest the Leatherman Knifeless Fuse http://www.leatherman.com/products/t...se/default.asp which team mates of mine and I carry.
Hope this helps
Simon Strauss
1155
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 07-11-2007, 22:21
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Jacob
So is the andymark stuff... we had a nightmare the other night finding metric tools for our dual shifter
I don't know if anyone else has mentioned this, but another thing you will need at a ready supply are hex wrenches and bondhuses. Our robot has a standard of 7/16 everything, and that was always the only hex wrench missing. So stock up on like 50 of your team standard to avoid tool hunting when your robot breaks 5 minutes before your final match (=
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 07-11-2007, 22:27
Billfred's Avatar
Billfred Billfred is offline
One other thing that I find myself relying upon more and more: a rivet tool. You can get one for $15 or $20, usually with rivets. For holding certain parts of the robot together, you can't beat it.
Unread 07-11-2007, 23:25
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Essential Hand Tools:
-Wrenches (7/16, 1/2, 9/16 mostly)
-Socket Set - The 1/4" size ratchet set w/ 7/16 & 1/2 sockets are the most used. If you ever need a 1/2" ratchet on a FIRST robot you probably need to rethink something.
-Screwdrivers - All sizes and types. Two or three of the more common types.
-Pliers (needlenose mostly for us over regular type but get both or a cheap set)
-Hex Key (Allen) Wrenches - We use the T handle type mostly in the shop and take the little foldup sets to comp.
-Ball Peen Hammer - use sparingly
-Wire Cutters
-Wire Strippers
-Crimp Tools for all those wire terminals you will learn to hate.
-Metal Files
-Deburring Tool A.K.A "Whirly-gig" - Be careful it will jump out of that hole when you look up and there goes the end of your finger!
Don't forget things to measure other things with:
-Tape Measure
-Ruler
-Digital Calipers are pretty handy
Clamps, lots of clamps, you can NEVER have too many clamps! We find good old C-clamps (4", 5", & 6") and those ViseGrip type clamps to be the most useful.
We also find rivet guns (both small (1/8" & 3/16) and large (1/4")) to be quite useful.
A few center punches. Once you start using one you will never know how you got along without one. Harbor Freight is your friend here. You can get them for a couple of bucks each. Get several because you won't be able find the one and only one you have under the mess on your work table about the beginning of February. A set of transfer punches are pretty handy as well. In fact Harbor Freight is a good place to get a lot of the above hand tools cheap.
There are special tools you will want for working with roller chain. A "chain breaker" will "break" a link in the chain to make two pieces. A "chain pincher" is pretty helpful to stretch the chain together like a third hand so that it is much easier to put the master link in.
You will probably be building at least a some part of the game field to practice on. Don't forget typical woodworking tools:
-Handsaw
-Claw Hammer
-Square
-Level
-A PVC cutter is usually helpful for something every year.
While you are building that practice field cut some short wood blocks about 6" to 8" long cut from a scrap 4"x4". Keep them near your robot build table. You will figure out what they are for the first time you want to test your new drivetrain on the table. Usually 4 of them will do the trick.
The basic power tools you should try to get if at all possible:
-Cordless Drill (w/ charger, extra battery(s), and a big box of drill bits)
-Drill Press (w/ another big box of drill bits)
-BandSaw (w/ several extra blades on hand for cutting aluminum)
-Miter Saw (yep, it will cut aluminum but be careful)
-Circular Saw
-Power tools that every team would love to have but few do:
-Milling Machine (CNC or manual)
-Metal Lathe
-Welder setup for aluminum
Power Tools that you might could use but can do without:
-Table Saw
-Air Compressor (Useful for blowing all the bits out of your robot before you power it up.)
Unread 07-11-2007, 23:39
Whoa there, guys, information overload! In addition to the often-repeated tools (which are probably the ones needed), this is a first-year team. I can't keep straight whether a tool has or hasn't been mentioned (though I know I missed the measuring tools--didn't think of those as tools). I think DeepWater has about as complete a list as you can find, categorized by type. Maybe we should let them sift through the info and decide what to get now and what to wait on until it is needed.
Unread 08-11-2007, 00:01
run the trap!!!
Team Role: Human Player
Yes, buying a welder is very expensive and you'll need a lot of practice - so its probably not a great idea to buy one.
But I HIGHLY encourage you to seek out a welding sponsor for your team.
Finding a welding sponsor is really easy. I know that in 2006 I just asked our local auto-repair shop if they could weld our robot and they were happy to do it free of charge. Welding can vastly speed up the build process and increase the quality of your robot. If you get your frame welded you can save weight on all the fasteners, and you don't have to worry about the structure of your robot coming loose.
-Philip J. Fry
Unread 08-11-2007, 00:26
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Funny how no one else mentioned it, but you will also need a space and an organization system to put it all. Trust me and our team's previously-disaster area Closet, after a few years stuff really begins to build up and clutter and dust begin to reign freely. Sorting years' worth of lost and abandoned drill bits from five or more sets is really not fun, especially when you and a couple of friends are the only ones without a major robot project on your hands :cough: freshman year :cough:
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
