Go to Post Lose lips sink... robots? (during a water game at least) - Zach O [more]
Unread 08-11-2007, 09:07
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Deventeh Digatal - CMPS03 - Robot Compass Module
I am in desperate need of help, I have been trying to integrate this compass for a while now with out any luck. At first we used interrupt code to read it, but the RC loop was too slow and did not give a accurate reading.
The compass has two interfaces, I2C, PWM. The PWM method is the one that did not work. Now since the RC is not compatible with I2C we bought a converter, it converts I2C to RS232. That means we have to connect it though the TLL port. But I have not experience with programming that port. Can anyone help me out. Anyone?
Thank You!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 08-11-2007, 09:59
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Deventeh Digatal - CMPS03 - Robot Compass Module
Thank You!
You may want to consider converting the PWM signal to an analog 0-5 Volt signal using something like this and then putting it into the analog in ports on the RC.
___________________
- Tennyson, Ulysses
Unread 08-11-2007, 11:35
I don't understand what you mean. Using interrupts should make reading the sensor independent of the "RC loop".
...since the RC is not compatible with I2C...
The RC will talk to I2C devices. You just need to write the program to control the I/O pins with appropriate timing.
Unread 08-11-2007, 14:38
Phil Mack Phil Mack is offline
FRC #0836 (RoboBees)
Phil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to behold
Hello,
first, start by using Kevin's implementation of the serial drivers. you can download that at http://www.kevin.org/frc/frc_serial_ports.zip
You can then use the Read_Serial_Port and Write_Serial_Port functions to asynchronously send and receive bytes to either serial port.
Check in the documentation for the converter and the documentation for the compass to find out what bytes to send. If you are still using the emicros device, the documentation is at http://www.emicros.com/useri2c.zip and explains what you need to send to the converter to send a message over the I2C bus. It has complete examples that show exactly what you need to do.
Good luck,
~Phil
Unread 08-11-2007, 16:34
Back after 4 years off
FRC #5279
Thank You!
To read the pulse width from the compass you really need to write an interrupt function that uses the internal clock to count when the signal goes high and stop counting when the signal goes low. You can take this count convert it into microseconds (bases on frequency of the controllers internal clock) and then divide that by 100 to get a number in degrees.
I am not sure if you are using it for FIRST but be warned computers and other large metal objects will severely effect the heading of the compass. I am using one for a project for one of my classes, in the room where we have class the magnetic field varies so much that when the car with the compass is told to drive in a straight line you end up driving in a wave like shape. However in better settings (in this case a huge gymnasium) we use the compass with the same control algorithms on a blimp and get much better results.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 08-11-2007, 19:08
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Hi John,
I already posted some code and instructions to help you out in another thread:
http://www.chiefdelphi.com/forums/sh...9&postcount=15
It'd be nice to hear one way or another if this worked out for you.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Programming a Devantech Magnetic Compass - CMPS03 kE7JLM Programming 7 28-09-2007 08:23
Interfacing a digital compass with the RC Kelly Electrical 14 27-09-2007 19:01
I2C Digital Compass Programming CyberWolf_22 Programming 7 03-01-2005 00:20
Political Compass Joshua May Chit-Chat 11 01-10-2004 22:32
Compass/direction sensor Frank(Aflak) Technical Discussion 10 06-04-2003 09:18
