Go to Post On a team, saying "it's not my job" is simply not acceptable. - dlavery [more]
Unread 08-11-2007, 14:00
Billfred's Avatar
Billfred Billfred is offline
Re: To Shift or Not To Shift, That is the Question
I have to echo the ideas above: it's all in your strategy. We wanted to be a fast arm robot, but I've had a hand in far too many flying bricks over the years for the robot to be unable to push. AndyMark Shifters allowed us to hit that sweet spot (ours, as I recall, were set for about 12 and 5.5 fps through sprocket and wheel choice).
What we do for next season will depend on a lot of things, at least on my end:
1) The game next year. Obviously, a robot that's going rock-crawling will not be using Uppercut's drivetrain.
2) Durability of the 2008 KOP gearboxes. If we can do the job with the kit gearboxes, I'll be more than happy to put them on. But if we had another year with gearboxes showing problems, I'd start investigating alternatives fast.
3) Resources available to us. If we need the $500 difference between AM Shifters and AM Gearboxes for other parts of the robot, decisions have to be made, particularly if item #2 is in question. (Ideally, of course, this would not factor into the equation.)
4) Familiarity. Given the choice, I'd much prefer to use a system someone else has had all the frustration fun of debugging already. ("Someone else" can be us.)
pic: Vex shift on the fly transmission Barry Bonzack Extra Discussion 1 30-04-2007 18:40
Making the KOP gearbox shift sanddrag Technical Discussion 4 26-03-2006 23:27
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
To shift or not to shift? sanddrag Technical Discussion 61 15-04-2003 22:56
