#8
Re: programing the vex optical shaft encoder
ok, i put in print statements before, in, and after the loop. before the loop, 'swerve' is zero. the first time though the loop, it's still zero, but the second time through it says 127!?!? so it quits the loop.
***EDIT*** i forgot to say that the print statement in the loop is AFTER it checks for the button Last edited by youngWilliam14 : 10-11-2007 at 13:24. |
| Problem using VEX shaft encoder | jskene | Programming | 15 | 28-10-2007 22:33 |
| VEX Shaft Encoder Kit | jeffmorris | FIRST Tech Challenge | 1 | 19-05-2006 12:23 |
| VEX Optical Shaft encoders in FRC | sanddrag | FIRST Tech Challenge | 8 | 04-10-2005 07:52 |
| Hollow Shaft optical encoders | magical hands | Robotics Education and Curriculum | 0 | 03-02-2005 22:56 |
| Rotary Encoder (optical etc.) | Gary C | Technical Discussion | 4 | 16-01-2005 18:23 |
