Go to Post There will be violence next year! YAY! - Koko Ed [more]
Unread 09-11-2007, 14:20
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Cool Frame Ideas?
Originally Posted by camtunkpa View Post
222 has a prototype bot to play the 07 game built from 80/20 quick frame and 1/16" lexan. The quick frame is basically 1" aluminum square stock with .060" wall. The connectors used to assemble the frame are made out of nylon. The prototype bot is going to its second competition this weekend(we won BE 6 last weekend thanks to our partners 1626,25 and 1923 for picking us) . It's been through one competition and so far so good. I will be writing up some more detailed information on this frame when we disassemble and check for stress on the nylon joints. So far we're convinced the 80/20 quick frame makes a good, strong, light, and easy to assemble frame. I will post more information as soon as I can.
Would you mind sharing from where you're getting the nylon connectors? I've been investigating using something like those recently and haven't found very many sources for them. I'm trying to get an idea for what's available, at what cost, and what the lead times are like for getting them delivered.
Thanks if you can help
--Madison--
...down at the Ozdust!
Unread 09-11-2007, 14:34
in between teams
AKA: Luke Van Oort
Your local 80/20 distributor should have them. The tube is $0.13 an inch (it is a special square extrusion with ridges on the inside of the tube, which I assume increase the strength of the connection) and the connector price varies depending on which one you get (straight through, t connection, 6-way, etc), but they all are between $2 and $3 each. My copy of the 80/20 price list is from last March so prices may have changed a tad, but these numbers should be pretty close.
Team 1219: 2009 - Mentor
Unread 09-11-2007, 15:32
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Originally Posted by dtengineering View Post
3/4" thin walled square tubing makes great superstructures!
I disagree. We use the 1 1/2" Aluminum tubing and it makes it much stronger. Last year, our robot got tipped over 3 times and did not show the slightest hint of damage. When making a frame, keep in mind that the best robot is lousy once it falls apart. The main point of the frame is to keep everything from falling apart. It does not necessarily have to be fancy, it just has to be functional. Remember, function over form.
Unread 09-11-2007, 15:36
Madison's Avatar
FRC #0488 (Xbot)
I didn't even think that it would be produced by the same folks that market the T-slot extrusion. Thanks.
Has anyone used these connectors with more conventional 1x1x.0625" tubing? I'd rather not need special tubing when I've got a local supplier for metal stock and a few dozen feet sitting in the workshop already.
--Madison--
Unread 09-11-2007, 16:21
dtengineering's Avatar
AKA: Jason Brett
Obviously 1 1/2" tubing is stronger than 3/4" tubing. It is also heavier and takes up more space. We have had no damage to our welded 3/4" thin-wall tubing superstructures for the past two years (despite "vigorous" interaction with other machines), but we do design our superstructures for using the finer tubing, with some good gusseting at the corners.
There is nothing wrong with making your robot stronger and stiffer, for as you say a broken robot is no fun. Teams need to make a trade off between strength and weight that only they can decide. We have found success building very durable, lightweight superstructures (which we weld to the KOP frame) with 3/4" square thin-wall Al tubing.
Jason
Last edited by dtengineering : 09-11-2007 at 16:54. Reason: clarifing 3/4" superstructure on KOP frame
Unread 09-11-2007, 16:25
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
You might want to check with someone on 1089 I know they use the connectors, but I think they are using standard aluminum. I will caution you though, the 80/20 tubing is ribbed on the inside to grip the nylon connectors better. Also I've been using http://stores.ebay.com/8020-Inc-Gara...Q3amesstQQtZkm
this store on Ebay. They have a pretty decent turn around time most parts ship in a day or two and you can generally find parts cheaper through them.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 09-11-2007, 16:28
I didn't say a thing about using it in the drivebase. Superstructure is the part of the robot above the drviebase. On our robot, we use 1 1/2" x 1" x 3/4" tubing for the drive frame and key superstructre (masts for arms, for example). 3/4" thinwall is used for stuff where we either need it to weigh nothing or we don't really care. It is pretty strong though. 330 used it for ramp framing last year. It supported about 140 lbs, often charging onto it, and we were more worried about the corrugated plastic being gouged than we were about the frame. I just wouldn't recommend using it for a drivebase.
Unread 09-11-2007, 16:45
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Here's a product I found...I haven't invested any funds to buy pieces for testing, but it looks great for making quick prototype frames:
http://www.eztube.com/
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 11-11-2007, 17:39
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
If a team had the money and time...
I'd love to see a demo robot built with polished brass or copper tubing.
Or one with some nice stained polished hard wood.
I know it would never work in competition hence the demo but it would look awesome and be a cool way to show off robotics in general.
Maybe in a off season there could be a American Robot build off
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 11-11-2007, 18:53
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Originally Posted by M. Mellott View Post
Here's a product I found...I haven't invested any funds to buy pieces for testing, but it looks great for making quick prototype frames: http://www.eztube.com/
Watch out!
We tried this stuff and it does look fantastic on paper, but they have a huge issue with being out of square. Well, not the connectors themselves, but what you put together with them. When we tapped our connectors in everything was nice and strong... but horribly out of square.
The robot frame we put together couldn't even hold an axle straight, let alone sit level. Maybe if you used force gauges or something when pressing the connectors in, or had really close tolerancs on the ID of the tube you use it would work... but just a heads up, with your ajax square tube it doesn't look too pretty...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 11-11-2007, 20:05
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
wilmo will become famous soon enough
Watch out!
The EZ Tube was exactally what I was looking for someone to say. Did you use your own extrusions or the Eztube extrusions made for the connetors, did you use the composite or the steel core?
Unread 11-11-2007, 20:29
Back after 4 years off
FRC #5279
Last year with 1493 we built a custom frame, the sides contained the transmission (a custom 2 speed based off the AndyMark shifter) and the wheels, the two sides were connected by 1 inch square tubing with 1 inch solid aluminum cubes welded on the ends. We threaded the cubes and connected the sides with counter sunk bolts. this allowed us to quickly remove one entire drive module and replace it with a spare. Allowing us to make repairs without having to miss matches of work directly around the robot.
I am going to attach a picture of the chassis, if you have any questions feel free to ask.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 11-11-2007, 21:06
Molten's Avatar
AKA: Jason
We do design our superstructures for using the finer tubing, with some good gusseting at the corners.
Maybe with gusseting, it would be fine. And I will admit some of the older teams make some great bases with the 3/4" tubing. However, to all of the new teams out there, you probably do not want to try this on your first bot. It works but you need to be well versed with stress analysis. Also, I suggest you have plenty of welders as I believe that you will have many more joints to cover. If, after reading this, you new teams are still confident on using this for your frame, Good Luck.
Unread 11-11-2007, 21:35
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Madison et al.
We have used 80/20 QuickFrame extensively for the last two years. We haven't used it for the chassis but for most all of the other structural components. It is really great stuff and easy to work with. All you need is a miter saw and a rubber mallet. If you want to take it apart heat the aluminum near the connector with a propane torch to expand the aluminun just a little and then the connector will usually slide right out to be reused. The only downside is the plastic connectors aren't exactly light and can start to add up if you are trying to squeze out that extra pound or two of weight budget. We bought a bunch of stock and connectors in 2006 and will probably need to restock some this year. I don't know where everyone else buys their 80/20 material but we went through our regional distributor and they gave us quite a nice educational discount. IIRC it was something like 40% and I was under the impression this was the standard 80/20 discount for all FIRST teams.
As far as using the connectors with standard 1" thin walled square tubing I really don't think it will work. The 1" square 80/20 QuickFrame tubing is specially fitted for the connectors. It has longitudinal ribbing inside that forms a friction lock with the plastic connectors. This is sort of the secret to the whole system. The internal dimensions of the QuickFrame tubing is slightly smaller (thicker walled than standard 1" thin wall box tubing) so if you try to insert a QuickFrame connector into standard 1" thin walled box tubing the connector will just fall out (too loose). The tubing isn't really that expensive though. IIRC the standard 1" QuickFrame box tubing was about $10-$11 per 12 foot (145") piece after the discount. They also have tubing with flanges on the side in different arrangements for putting panels in, etc. We purchased some but didn't really use the flanges much and often just cut them off to save weight.
One trick we found was to drill a hole in the end of the tube through into the connector and put a pop rivet in on any connectors you REALLY don't want to back out. This trick is rarely needed but is cheap (and light) insurance.
There are also 80/20 "transition" connectors available to use QuickFrame in combination with 1010 series where needed.
Search CD media photos for our team number "456" and there are 4 photos, 2 of our 06 and 2 of our 07 (1 lifting our 06) robot showing lots of use of 80/20 QuickFrame.
Oh yeah, we have used the KitBot frame for the last two years but the QuickFrame matches perfectly to the 1/4" 1" spaced hole pattern of the KitBot frame if you use the little base connector (part number 9140(gray) or 9240 (black)).
Hope this helps. Any more questions just ask.
Edit: I forgot the mention that 80/20 QuickFrame isn't really made by 80/20 but rather by Esto.
Unread 11-11-2007, 21:50
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
We have used welded 1" aluminum for our frame 3 out of the last four years with great success. The other year we used the kit box frame welded together.
We have also used 1" thin wall for the superstructure but connected together with gussets and rivets. No need for fancy connectors or welding. Only tools needed are a hacksaw, tin snips, a drill and pop rivet gun.
the frame kaboose Technical Discussion 7 11-01-2007 22:38
Riveting up a frame Billfred Technical Discussion 27 19-12-2006 19:49
Cool new ideas for FIRST Robots - who has them? sanddrag General Forum 44 04-08-2005 15:02
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
