Re: Cool Frame Ideas?
Here's a product I found...I haven't invested any funds to buy pieces for testing, but it looks great for making quick prototype frames:
http://www.eztube.com/ |
We tried this stuff and it does look fantastic on paper, but they have a huge issue with being out of square. Well, not the connectors themselves, but what you put together with them. When we tapped our connectors in everything was nice and strong... but horribly out of square. The robot frame we put together couldn't even hold an axle straight, let alone sit level. Maybe if you used force gauges or something when pressing the connectors in, or had really close tolerancs on the ID of the tube you use it would work... but just a heads up, with your ajax square tube it doesn't look too pretty... -q |
Last year with 1493 we built a custom frame, the sides contained the transmission (a custom 2 speed based off the AndyMark shifter) and the wheels, the two sides were connected by 1 inch square tubing with 1 inch solid aluminum cubes welded on the ends. We threaded the cubes and connected the sides with counter sunk bolts. this allowed us to quickly remove one entire drive module and replace it with a spare. Allowing us to make repairs without having to miss matches of work directly around the robot.
I am going to attach a picture of the chassis, if you have any questions feel free to ask. ![]() Last edited by JamesBrown : 11-11-2007 at 20:32. |
If I Recall it was just an ease of mounting decision. We wanted wide wheels in the center to push but didn't want to have to make the whole drive module wider.
#8
Now that I've had time to look, the 80/20 system and the EZ Tube system look very similar, at least in concept, even with the availability of extruded tubing with panel-mounting flanges. EZ Tube connectors seem longer and have the option of the steel-core reinforcement (probably adds too much weight for a robot frame...probably). Of course, if you're not worried about reusing the connectors, you could always use standard thin-wall 1" tubing and some two-part epoxy like JB Weld. |
| the frame | kaboose | Technical Discussion | 7 | 11-01-2007 22:38 |
| Riveting up a frame | Billfred | Technical Discussion | 27 | 19-12-2006 19:49 |
| Cool new ideas for FIRST Robots - who has them? | sanddrag | General Forum | 44 | 04-08-2005 15:02 |
| Voltage on Frame | Greg | Electrical | 31 | 02-03-2004 13:49 |
| Frame connections | manleycor | Technical Discussion | 15 | 18-11-2003 01:14 |
