Go to Post Yep, after all, when life gives you lemons, make a robot to pit and squeeze them, purchase sugar, cups, water, and ice and make lemonade!! - vivek16 [more]
Unread 09-11-2007, 19:24
Gamerboyb1's Avatar
Gamerboyb1 Gamerboyb1 is offline
Sean Goodrich (Sparx 1126)
AKA: Sean Goodrich (Sparx 1126)
FRC #1126 (Sparx)
Gamerboyb1 is an unknown quantity at this point
Send a message via AIM to Gamerboyb1
Exclamation Drives in general
What would be the best kind of drives system:
Four wheel mecanum drive system
six wheel drive pivoting off the center wheel
8 wheel drive with 4 transmissions
6 wheel drive system with turning wheels
Thanks to all who respond it will help a lot!!
Unread 09-11-2007, 19:42
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Drives in general
You will need to define best for what a little more. "Best" depends on what your objective is.
Unread 09-11-2007, 20:08
Gamerboyb1's Avatar
FRC #1126 (Sparx)
I would have to say for mobility and pushing power
Unread 09-11-2007, 20:14
All of them, plus all the options you didn't mention. Why? The game objective changes, so your objective(s) change. Different objectives need different equipment to obtain them. For example, a mecanum system can be good for precise positioning without having to back out, realign, and come back. The six-wheel dropped center design is a good all-around design, but it can have trouble with being easily spun when hit hard (which can be designed around).
Also, could you clarify what you mean by "6 wheel drive system with turning wheels"? I mean, all the wheels in a drive system turn normally; otherwise, the robot doesn't drive... Do you mean a combination of a crab system (all wheels rotate to allow the robot to go sideways without turning) and a six-wheel system, like the Chariot uses?
Unread 09-11-2007, 20:17
Gamerboyb1's Avatar
FRC #1126 (Sparx)
sorry about that i was at a loss for words.
i meant a swerve drive system almost like a car set up.
Unread 09-11-2007, 20:27
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
If you factor in mobility, pushing power, and drivability, I would go with 6wd. You get great traction, you don't need to worry about turning, and unlike a crab drive, the difficulty that a driver would experience is minimal. It's also easy enough to accomplish a 6wd with pretty much all kit and IFI parts.
The downside to 6wd is the weight of added chain and wheels.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 09-11-2007, 20:52
Gamerboyb1's Avatar
FRC #1126 (Sparx)
yeah but wouldn't the 4 wheel system give the best turning potential and pushing power because it would have more surface area with 2 more wheels?
Unread 09-11-2007, 20:59
I only know of one team who has tried a car-style steering. I don't think it worked as well as they hoped. (And I don't remember it doing well at competition.) Personally, I think car-style is a little too complex to do on a FIRST robot.
I think that most people are going to say either 6WD with dropped center or mecanum. AndyB is right on the money there; you can practically make one right out of the kit. I'm not sure that the extra weight is enough to be a factor; at least, if you design for it to be there, you can make adjustments before building.
EDIT: I don't understand your last question. Do you mean the 8-wheel system you proposed?
Unread 09-11-2007, 21:03
AndyB's Avatar
AKA: Andy Burchardt
I'm assuming by 4 wheel, you mean 8 wheel.
Technically, traction is not affected by the change in surface area. The weight is just displaced. However, with the roughtop tread surface (if thats what you choose to use), your traction doesn't so much come from friction rather than the fact that the tread digs into the carpet. So yes, you may have more traction. Not that I've actual looked for it, but I can't say I've ever seen an IFI traction wheel slip on carpet with the roughtop tread.
As far as turning goes, you aren't pivoting on two wheels, you are pivoting on four which doesn't have much of an affect considering the distance between the pivoting wheels.
When it comes down to it though, 8wd's aren't as easy to make and of course the weight again goes up. I guess it all comes down to personal preference. The benefits of an 8wd in my opinion is outweighed by the weight.
If you look at last year, the teams with the best drives came from the likes of 330, 1114, 2056... etc. These were all 6wd 'bots. They all had extra weight for solid arms and ramps/swiss-army-knives(1114). If go by the logic of a perfect driver, I'd probably hand it to 4 wheel crab, but again, manufacturing difficulty goes up quickly. In the FIRST world, 6wd is easier to drive.
Unread 09-11-2007, 22:12
Gamerboyb1's Avatar
FRC #1126 (Sparx)
no when i said 4 wheel i meant only four wheels.
I made a comment in the first post about a 8 wheel drive system
Unread 09-11-2007, 22:22
in between teams
AKA: Luke Van Oort
Assuming that you mean just 4 wheel drive without omni wheels, pop-casters, or other such devices, then the answer is no. For the traction bit, as said above, for the most part, traction is independent of surface area in contact with the carpet. 4WD is a path with several pitfalls that must be avoided, and its maneuverability can turn into one of them. If a 4WD (again, assuming no omnis, pop-casters, and that kind of stuff) is longer than it is wide it will not turn well. On the other hand, a 6WD using the same wheels will always turn better (assuming the middle wheel is lowered or coplanar, not raised off the ground) than a 4WD of the same LxW dimensions. This characteristic along with the 6WD's inherent resistance to bottoming out on inclines are two of the major reasons that it is so popular among teams nowadays.
Team 1219: 2009 - Mentor
Unread 09-11-2007, 22:30
4WD often equals bouncy turns. It has to be done just right to eliminate that (usually omnis or casters, though the casters make it a 2WD). Almost the only easy way to eliminate this is to build a "wide" bot (the short side is front-to back), and then you have a tipping risk under normal driving. The most successful robot I have seen with 4 wheels is 69 in 2005. (At least, I remember them as having only 4.) They had very slick wheels, as I remember, so they slid a little bit.
Unread 09-11-2007, 22:32
AndyB's Avatar
AKA: Andy Burchardt
Originally Posted by lukevanoort View Post
Assuming that you mean just 4 wheel drive without omni wheels, pop-casters, or other such devices, then the answer is no. For the traction bit, as said above, for the most part, traction is independent of surface area in contact with the carpet. 4WD is a path with several pitfalls that must be avoided, and its maneuverability can turn into one of them. If a 4WD (again, assuming no omnis, pop-casters, and that kind of stuff) is longer than it is wide it will not turn well. On the other hand, a 6WD using the same wheels will always turn better (assuming the middle wheel is lowered or coplanar, not raised off the ground) than a 4WD of the same LxW dimensions. This characteristic and resistance to bottoming out on ramps are what make the 6WD so popular among teams nowadays.
Thanks for clarifying. I forgot about the ramp part. The two out of three years, the game has involved getting up a ramp. If you consider getting unstuck from the tetra goals, then all three involved an some amount difficulty. With six wheels, ramps are not really a problem (assuming ground clearance) and you don't see many teams with 6wd getting stuck on parts of the playing field because you pretty much always have at least 2 wheels on the ground, if not four or six.
I have never worked with anyone, so if you have (Cyberblue ) on a hex drive (six wheels with middle wheels moved)
http://www.chiefdelphi.com/media/photos/27420
Do teams lower the middle wheel or is the point of moving them out so that they don't need to be lowered or lowered as much.
Unread 09-11-2007, 22:55
Gamerboyb1's Avatar
FRC #1126 (Sparx)
no when i say 4 wheel i mean with omni wheels.
that would be a very big act of lessened intelligence to just use regular wheels.
Unread 09-11-2007, 23:17
AndyB's Avatar
AKA: Andy Burchardt
Omni wheels are nice for the fact that you still get a little bit of forward traction with them. However, once again, you still risk bottoming out on ramps as well as the fact that defending a robot with omni wheels in the front is relatively easy. With six wheel drive... not so easy.
I also wouldn't consider using four regular wheels as "lessened intelligence". Four wheels is perfect for any robot running long-way-forward. Four wheels is also pretty much required for a crab drive. I have never seen a six wheel crab drive on a FIRST robot. But I can't say I wouldn't enjoy it.
However, for a team looking to focus less on the drive and more on a complicated manipulator or ramp system, four wheel drive with omni wheels in front is as easy as it comes.
Crab Drives at Nats Joe_Widen General Forum 3 23-04-2006 22:37
holonomic drives Max Lobovsky Technical Discussion 5 10-03-2004 21:31
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
