Go to Post "FIRST: We take young human beings, born in captivity, educate them in science and technology, and re-release them into the wild." - kmcclary [more]
Unread 10-11-2007, 14:53
Back after 4 years off
FRC #5279
Re: programing the vex optical shaft encoder
Originally Posted by youngWilliam14 View Post
ok, i put in print statements before, in, and after the loop. before the loop, 'swerve' is zero. the first time though the loop, it's still zero, but the second time through it says 127!?!? so it quits the loop.
***EDIT***
i forgot to say that the print statement in the loop is AFTER it checks for the button
Assuming swerve is defined as a char then that makes sense, it should equal 127 if the button is pushed.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Problem using VEX shaft encoder jskene Programming 15 28-10-2007 22:33
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
VEX Optical Shaft encoders in FRC sanddrag FIRST Tech Challenge 8 04-10-2005 07:52
Hollow Shaft optical encoders magical hands Robotics Education and Curriculum 0 03-02-2005 22:56
Rotary Encoder (optical etc.) Gary C Technical Discussion 4 16-01-2005 18:23
