thoughts about image processing
Hi guys,
just thinking of an after-project, as mine is nearing it's end. thought about getting into image processing, CmuCam,webcams, etc. just wondering, how do I get started? what do I need? (I program using C & ASM,I hope no new languages are necessary) and what to expect? thanks, Ran. =] |
Re: thoughts about image processing
What do you want to get out of your image processing?
I have done/seen image processing done well in LabVIEW, MATLAB and Python (in descending order of awesome). I'm sure you could do just as well in C, you'll just need to find a good library. It is also fun to play with OpenGL - try nehe.gamedev.net |
I've used OpenCV which is an Intel library which became an open source project to try some things. You can find out about it here: http://opencvlibrary.sourceforge.net/ There is quite a bit of other information available if you search the web. Getting it set up can be a little tricky but one you have on of the simple webcam image capture programs set up and working, you can easily modify it. There are also some good image processing articles on CodeProject.com. Some show the effects on existing digital pictures so you can bypass the whole image capture process while you're learning image processing techniques. |
thank you both very much,
uhh.. Tim, you said that the CMUCAMs aren't so great for a starting point, but you didn't mention what would be, is a standard webcam better? in addtion, i understood you guys have experience with PC connected cams, I was thinking more in the sense of using the cam with a smaller controller, (such as a large PIC), if that's my larger objective, where should I start? Thanks again, Ran. |
actually, i found areally great library for recognizing colors once... i wish i could remember the name, i will go search for it and when i find it i will give you the link
http://www.jrobot.net/Projects/AVRcam.html |
| Thoughts about future autonomous scoring... | JimGRobot | Programming | 12 | 04-04-2007 00:01 |
| Critique my image processing program... | Salik Syed | Programming | 13 | 29-06-2006 16:57 |
| Thoughts about the future FIRST games | David55 | General Forum | 7 | 24-05-2006 00:34 |
| Just some thoughts about FIRST I had while trying to fall asleep during build season | Racer26 | General Forum | 31 | 20-03-2004 11:27 |
