Go to Post No FIRST event is complete without Darude's Sandstorm. - sonichammer7476 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #31   Spotlight this post!
Unread 10-11-2007, 21:22
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
Re: Nintendo DS Scouting System
i put the file "DSSCOUTv0.3.nds" on to the cf card of my max media dock and it runs, but i don't think it saves. does it still save to "INFO1.txt"?
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
  #32   Spotlight this post!
Unread 10-11-2007, 21:23
AKA: Will Crabtree
btw, are you going to update the program for next years game?
  #33   Spotlight this post!
Unread 10-11-2007, 21:37
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
If it saved to the file (which is should, and if info1.txt doesn't exist, it will create it in the same directory as the bin file) you should see some numbers corresponding to the ones you entered when you saved.
And yes, I plan on recreating the scouting program during the build season, or at least before the first regional so teams have the opportunity to download the correct scouting program if need be.
On that note, I should say the the library I planned on creating is on a stand-still due to the amount of other work I have. I plan on finishing it, but not before this upcoming frc season. I will, however, as mentioned above, create a generic scouting program for all teams wanting one.
  #34   Spotlight this post!
Unread 10-11-2007, 22:11
AKA: Will Crabtree
will that include a pit scouting form?
and as for saving, i have the txt file on there, but it just sits there and basically freezes the system.
  #35   Spotlight this post!
Unread 11-11-2007, 18:53
Unregistered User
AKA: Kevin Forbes
I haven't heard of any other requests for a pit scouting form, but now that you mention it, that might come in handy! So sure, why not?
As for your scouting problem... not having a CF card myself, I cannot answer your question accurately. Is your CF card formatted with the FAT system? It may just be that the program doesn't work on Compact Flash cards, unfortunately...
[IMG] code is Off
Your Scouting System Dantvman27 Scouting 36 11-03-2007 15:12
Team 66 Scouting System David66 Championship Event 0 11-04-2005 19:39
Scouting System Name Jack FIRST Scouting Network 10 04-05-2003 21:30
