| View Poll Results: What was your final gear ratio on your drive? | |||
| < 10:1 (not inclusive) |
0 | 0% |
| 10:1 (inclusive) to 12:1 (not inclusive) |
0 | 0% |
| 12:1 (KOP) |
6 | 37.50% |
| 12:1 (not inclusive) to 15:1 (inclusive) |
2 | 12.50% |
| > 15:1 (not inclusive) |
4 | 25.00% |
| Multispeed (Post your gear ratios) |
4 | 25.00% |
| Voters: 16. You may not vote on this poll | |||
Last Year's Gear Ratio
Ok, so on your drive, what was your final gear ratio after gearbox and sprocket reduction. Keep in mind that the KOP transmissions are about 12:1. (Assuming a 6" wheel size with four CIMs. If anything else, please specify)
<10:1 >10:1 and <12:1 12:1 >12:1 and <15:1 >15:1 If you used multispeed gearboxes, post your ratios. 269 used a 15:1 ratio using worm gears. Last edited by AndyB : 11-11-2007 at 00:43. |
Re: Last Year's Gear Ratio
For this to be meaningful, you also need to describe wheel size....
16:1, banebots with the added stage, 6" wheels.
Also for this to be meaningful, you may want to consider which motors are being used for driving. While many use CIM's, some also use FP's and/or the mini-bike CIM (fat chip). Therefore the gear ratios used for those motors should not be compared with other motors.
We used 12:1 Banebots with the DUAL CIM configuration and additional 1.3:1 geardown to the 6" wheels for a total of about 16:1. The results end up with 6.25 ft/s at 40 Amp draw and 9 ft/s at free speed. No shifters last year. |
We had a Small CIM, big CIM and FP w/ AM planetary on each side. The ratio of the Small CIM (which the other motors were matched to) was about 12:1.
This was driving 6 inch wheels. |
| Transmission gear ratio | MASherry | Technical Discussion | 6 | 13-01-2005 10:32 |
| Help with gear ratio | Wayne C. | General Forum | 6 | 26-01-2004 12:30 |
| Helical Gears Gear Ratio | Joe P | Technical Discussion | 11 | 23-01-2003 22:55 |
| gearing for last year's gear cluster for the chipuhua motor | Antonio | Motors | 0 | 07-01-2003 15:31 |
| Gear Ratio Doesn't Matter | Paul Copioli | Technical Discussion | 2 | 27-09-2001 08:18 |
