Go to Post Someone wake me up the day of Kickoff. - Andrew Schreiber [more]
View Poll Results: What was your final gear ratio on your drive?
< 10:1 (not inclusive) 0 0%
10:1 (inclusive) to 12:1 (not inclusive) 0 0%
12:1 (KOP) 6 37.50%
12:1 (not inclusive) to 15:1 (inclusive) 2 12.50%
> 15:1 (not inclusive) 4 25.00%
Multispeed (Post your gear ratios) 4 25.00%
Voters: 16. You may not vote on this poll
Unread 10-11-2007, 23:43
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Last Year's Gear Ratio
16:1, banebots with the added stage, 6" wheels.
Unread 11-11-2007, 00:34
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Also for this to be meaningful, you may want to consider which motors are being used for driving. While many use CIM's, some also use FP's and/or the mini-bike CIM (fat chip). Therefore the gear ratios used for those motors should not be compared with other motors.
We used 12:1 Banebots with the DUAL CIM configuration and additional 1.3:1 geardown to the 6" wheels for a total of about 16:1. The results end up with 6.25 ft/s at 40 Amp draw and 9 ft/s at free speed. No shifters last year.
Unread 11-11-2007, 01:17
AdamHeard's Avatar
Lead Mentor
We had a Small CIM, big CIM and FP w/ AM planetary on each side. The ratio of the Small CIM (which the other motors were matched to) was about 12:1.
This was driving 6 inch wheels.
Transmission gear ratio MASherry Technical Discussion 6 13-01-2005 10:32
Help with gear ratio Wayne C. General Forum 6 26-01-2004 12:30
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
gearing for last year's gear cluster for the chipuhua motor Antonio Motors 0 07-01-2003 15:31
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
