Go to Post note: spelling, punctuation and good grammar are your friends - use them and enjoy the benefits of legible, understandable prose - dlavery [more]
Unread 11-11-2007, 08:04
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Talking Crazy idea involving hundreds of LEDs
For the past couple of days, I thought it would be *really cool* to make either my own marquee hat, or eventually a vest of LEDs. It could display words or pictures (using PWM to dim the lights and get something besides ON and OFF) and it would be really hard to not notice a flashing LED vest.
Now, since I'm just a programmer, I'm used to having all the outputs on my processor. As far as I know, there's not a processor in the world with a few thousand outputs...that would be impractical and stupid. But how do I multiplex? What chips are available?
I started Googling around, and remembered seeing Christmas light controllers on computerchristmas.com and immediately went there. On that site, there's 2 different methods of controlling lights; one involving flip-flops and decoders (Link) and one with 595 shift registers (Link).
Both of these seem horridly inefficient, especially if the final goal is to have thousands of channels (can you picture me with a huge box of flip-flops on my back? ). Is there a better method? I'm probably going to learn some of this at college, but I'm not there yet (I wish...).
How do real commercial marquees do it? They have cool multi-color effects and fading in and out...I'm sure it's all pulse-width because I can see them flicker.
So....any suggestions would be greatly appreciated.
JBot
Aren't signatures a bit outdated?
Last edited by JBotAlan : 11-11-2007 at 08:05. Reason: Oops...It's URL, not LINK...
Unread 11-11-2007, 09:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Crazy idea involving hundreds of LEDs
see if you can figure out how monitors work.
Seems to me that you're just trying to make a low resolution monochrome monitor, using LEDs
Unread 11-11-2007, 11:48
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Here is something to take a peek at! Link
We have over 33,000 LED's on it including a strobe to each panel. We use the serial port on the back of a laptop in order to control 34 different micro controllers which in turn control four different triangles. I really can't elaborate too much on how it works, but Alan Anderson can.
I win! XD
Unread 11-11-2007, 11:57
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
well daft punks has a helmet that dose that you could try to email them and see how they did it
If it isn't broken, Fix it till it is ~ Baker
Unread 11-11-2007, 14:03
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
I saw an awesome vest with fiber optic lights woven in it. It diplayed the coolest light show on his back. At the 2006 Boston match, there were people from MIT's Waerable Computer lab. http://www.media.mit.edu/wearables/index.html
Unread 11-11-2007, 14:26
Jacob,
LED displays frequently use row/column multiplexing to make moving and animated displays. An LED only needs to be turned on for a short period of time for the human eye to notice it. As long as the refresh rate exceeds 24 Hz (30Hz is the TV vertical frame rate) then the human eye integrates the LEDs into a still or moving frame. You then just need to produce row and column switch generators and output a control signal in sync with the row/column encoder.
Unread 11-11-2007, 15:29
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Dynamo from "Running Man"
Unread 11-11-2007, 21:00
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
we've talked about doing something like this...
one way you could try doing this is with n-bit counter chips, attaching an LED to each bit of the counter, then count up on the counter until you get to the state you want. processor should be able to do it faster than you could notice, although using 4-bit counters doesn't expand your ability too much.
i'm no EE, but if someone who is could critique this idea, that would be awesome:
you arrange your LEDs in a matrix, with one end of the diode connected in each column to every other in the column and the other end of the diode connected in the row to every other in the row. each row and each column's continuity is controlled by a transistor, so closing the transistor on a row and a column will complete the circuit. not sure how you'd deal with the current requirements of LEDs to avoid blowing them or anything, or if this will work at all, but just throwing it out there. i could probably draw a schematic if my description wasn't clear...
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 11-11-2007, 22:14
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I found a concise article describing how LED matrices work here: http://www.acm.uiuc.edu/sigarch/tutorials/ledarray/
This is more or less the way I've always seen it done.
It's a pretty good idea, but instead of a counter just use a shift register (as described above).
As has already been discussed, the only realistic way to build a large LED array is to scan through them using rows and columns. Once you have that in place (using just ON or OFF states for each LED), you can then implement brightness by scanning faster. For example, if you normally turn on one of the LEDs for 10 milliseconds when it's supposed to be "ON", you can subdivide that 10ms further to implement brightness. ON 2.5ms OFF 7.5ms for 1/4 brightness, ON 5ms OFF 5ms for half, etc. The challenge here is not having so many LEDs that your scan time for each LED is too low. Depending on how many LEDs to want to have total, you might have to break down the overall matrix into smaller grids and have a microcontroller dedicated to each grid. If you want color, then repeat the whole process with a different color LED. Once you do that, then you need to figure out how to communicate with all of them. As you can probably tell, the basics of an LED matrix are straightforward, but the practical implementation can get complicated.
Unread 11-11-2007, 23:40
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
This hat is pretty cool. I think it uses shift registers and an array of leds. Too much soldering for me.
Unread 12-11-2007, 00:14
rainy846's Avatar
rainy846 rainy846 is offline
AKA: Yuzhi
FRC #0846 (Funky Monkey)
rainy846 will become famous soon enoughrainy846 will become famous soon enough
we though of like a LED moving team sign thing.
the programming part shouldn't be too bad (well, depends on how complicated you want to make it), but finding a portable power supply was a problem for us.
Go FUNKY MONKEYS!!!
846!!!
Attending : Silicon Valley Regional, Hawaii Regional
2007:
4th Seed Silicon Valley Regional Semifinalist
1st Seed Lone Star Regional Semifinalist
Woodie Flowers Award for our Mentor : Mr. Xie Silicon Valley Regional
Gracious Professionalism at Lone Star Regional
Unread 12-11-2007, 11:57
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
What I suggest you use is a family of 8255 Programmable Peripheral Interface chip ($5 From Jameco).
Essentially, what an 8255 gets you is 24 bits of I/O from 8 pins on your processor. (An 18F8722 has I believe 8 ports of I/O or 64 lines, so, if you really wanted to just with one level of multiplex, one 8255 chip per port, you could run 192 led's). The interface is REALLY simple, just sit down with the data sheet and about one cup of coffee (or tasty beverage of your choice) later you should have enough knowledge to go out and hook up an 8255 to your processor of your choice.
Of course, if 192 output lines isn't enough, you can just add another level of multiplexing (1 byte I/O from processor => 1 8255 Chip => One 8255 chip for each byte on the previous=> 9 bytes of I/O per 1 byte of processor I/O (or 72lines per every 8)). So, if you added one more level of multiplexing on all of those ports you'd still EASILY make your update rate with the 18F8722 (or other 40MIPS+ processor) and be able to run up to 576 led's.
BUT! Remember to put resistors in series with your leds or you'll easily go over the 2.5mA per line drive current. You'll most likely need a darlington array IC to drive your LED's in the end if you want bright ones... but thats another story which i'll write if there is interest.
Have fun! Sounds like a fantastic for-the-heck-of-it-project!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 12-11-2007, 14:01
Software Engineer
Rookie Year: 1995
2.5mA is likely not going to cut it. We typically supply 10mA to LEDs in our projects, and that is acceptable but usually not super-bright, and this is for regular status LEDs that are not multiplexed. When you multiplex them, they're only on for a fraction of the time, making them appear even dimmer than usual.
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
500 hundreds of a inch JulieB General Forum 8 18-02-2005 01:09
Crazy NEW Idea! Kyle Love Championship Event 14 07-11-2004 16:50
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
