Go to Post How come CD doesn't have a "Like" button??? - dlavery [more]
Unread 12-11-2007, 00:35
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: thoughts about image processing
Originally Posted by 3dude_2231 View Post
thought about getting into image processing,
CmuCam,webcams, etc.
just wondering,
how do I get started?
what do I need? (I program using C & ASM,I hope no new languages are necessary)
and what to expect?
The CMUCam that was distributed with the KOP is very limited for really learning image processing techniques since you're limited to what the firmware that's part of the camera system can do. The new CMUCam3 is more flexible since you can install your own software but is probably not a great place to start.
I've used OpenCV which is an Intel library which became an open source project to try some things. You can find out about it here:
http://opencvlibrary.sourceforge.net/
There is quite a bit of other information available if you search the web. Getting it set up can be a little tricky but one you have on of the simple webcam image capture programs set up and working, you can easily modify it.
There are also some good image processing articles on CodeProject.com. Some show the effects on existing digital pictures so you can bypass the whole image capture process while you're learning image processing techniques.
Unread 12-11-2007, 09:22
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
thank you both very much,
uhh.. Tim, you said that the CMUCAMs aren't so great for a starting point,
but you didn't mention what would be, is a standard webcam better?
in addtion, i understood you guys have experience with PC connected cams,
I was thinking more in the sense of using the cam with a smaller controller,
(such as a large PIC), if that's my larger objective, where should I start?
Thanks again,
Ran.
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 12-11-2007, 10:35
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
actually, i found areally great library for recognizing colors once... i wish i could remember the name, i will go search for it and when i find it i will give you the link
Unread 12-11-2007, 13:26
AKA: Tim Craig
Yes, a webcam with a desktop or laptop would be a better setup to learn actual image processing. The development and debugging cycle would be some much faster and simpler than using a small system where you have to continually develop on a bigger computer anyhow, download it to the target, and have very limited debugging capability. Not to mention the limited memory and processing power. Image processing can be very memory and compute intensive and for the educational part you probably don't want to skimp on either. Once you learn, then you can port it to a small system.
One alternative to the CMUCam that I know of for small systems is the AVRCam. It's inexpensive and you can play with its programming. I believe it uses the same camera module that the CMUCam uses so you could potentially save that cost as well but you need to verify that. The toolset to program it is free as well. A lot of the people in the Silicon Valley Homebrew Robotics Club use AVR instead of PIC for their bot controllers.
http://www.jrobot.net/Projects/AVRcam.html
Thoughts about future autonomous scoring... JimGRobot Programming 12 04-04-2007 00:01
Critique my image processing program... Salik Syed Programming 13 29-06-2006 16:57
Thoughts about the future FIRST games David55 General Forum 7 24-05-2006 00:34
Just some thoughts about FIRST I had while trying to fall asleep during build season Racer26 General Forum 31 20-03-2004 11:27
